AiM Solo 2 & Solo 2 DL 2m 5 Pin externe Power Lead Feuerzeug Sockel Typ
Connect Your System
The Aim Solo 2 External Power Cable fits with the Aim Solo 2 & 2 DL GPS Lap Timers and features a 5-pin 712 male binder connection, which goes into the GPS Lap Timer. The 12V lighter socket plug on the other end allows you to connect to the car's power source. The high-quality cable length is 2m in total and is designed to withstand motorsport environments.
Why Choose the Aim Solo 2 Power Cable
The Aim Solo 2/2 DL External Power Cable features a metal 712 screw-on connector with 5-pins in the housing, always ensuring reliable signal transmission in high-vibration environments. The other end has a car lighter socket plug to provide a continuous 12V power supply to the lap timer for the entire track day session. This ensures that you get the most out of your lap timer during track days, allowing you to view your data for an extended period of time.
Solo-Feuerzeug-Stecker-Stromkabel
