Aim Solo 2 DL Plug & Play Cable for GET Motocross ECU
Connect Your System
The Aim ECU Plug & Play Cable has been designed for 4-stroke dirt bikes and can be used with the Aim Solo 2 DL GPS Lap Timer to allow ECU data to be logged. There are a range of supported models for this particular plug & play cable, ranging from GET GP1 with EVO protocol, GET GP1 with A4 protocol and GET Power.
Why Choose the Aim Solo 2 DL Plug & Play Cable
The Aim Solo 2 DL Plug & Play Cable is suited to a range of GET Motocross ECUs, meaning that a wider range of people can connect to their Aim Solo 2 DL via a secure 712 7-pin male binder connector. It provides a simple plug & play connection so that you can easily, efficiently and quickly get your motocross bike ready for track days.
As it is designed for harsh motocross environments, the GET ECU cable is a high-quality and long-lasting cable, ensuring that it will not be damaged, so that you can get your bike's data as soon as possible.
Plug & Play Compatibility
This Solo 2 DL Plug & Play Cable is compatible with the following GET motocross models:
- GET GP1 with EVO protocol
- GET GP1 with A4 protocol
- GET Power
If you are unsure whether this ECU cable will fit your motocross bike, don't hesitate to contact our team.
Solo 2 DL GET ECU-Kabel
