Aim Solo 2/Solo 2 DL Lap Timer Sun Shade Visor
Keep your lap times clearly visible, even in bright sunlight, with the Aim Solo 2 and Solo 2 DL Sun Shade Visor. Designed to reduce screen glare in open cockpits, road cars and challenging lighting conditions, this lightweight visor extends 29mm beyond the display to provide effective shading without obstructing your view.
Featuring a precision-fit design and a durable, matte black finish, the visor offers a practical way to improve screen visibility while maintaining the original look and functionality of your lap timer.
Why Choose the Lap Timer Visor?
Bright sunlight and reflections can make your lap timer difficult to read, particularly when driving in low sun or vehicles with large glass areas.
The Sun Shade Visor helps minimise glare, keeping your lap times and performance data easier to see at a glance. Its smooth, contoured design follows the shape of the Solo 2 housing, providing a clean, factory-style appearance that complements your existing setup.
Designed specifically for the Aim Solo 2 and Solo 2 DL, the visor offers:
  • Reduced Screen Glare: Helps maintain display visibility in bright sunlight.
  • Precision Fit: Contoured to match the shape of the Solo 2 housing.
  • 29mm Extended Shade: Provides additional screen protection without obstructing the display.
  • Full Accessibility: All buttons and connectors remain accessible.
  • Mount Compatibility: Works with all standard Solo 2 mounting brackets.
Fitting the Visor
The visor features a simple push-fit design, allowing it to attach directly to your Aim Solo 2 or Solo 2 DL without tools, adhesives, additional clips or modifications.
Its contoured sides wrap around the full height of the lap timer, locating securely into the notch at the top of the housing and the rear corner recesses. Integrated internal snap beads engage behind the rear rim, holding the visor firmly in position.
Once fitted, the original Aim mounting bracket can be installed over the rear of the unit as normal, ensuring compatibility with existing Solo 2 mounting solutions.
Materials
Manufactured from ASA (Acrylonitrile Styrene Acrylate), the visor is designed to withstand the demanding conditions found inside motorsport vehicles.
Unlike conventional 3D-printing materials such as PETG or ABS, ASA offers excellent resistance to UV exposure and high temperatures, helping the visor maintain its shape and appearance even in direct sunlight or hot vehicle interiors.
Its durable construction and matte black finish provide a refined, factory-style appearance, making it a practical addition to your lap timer.
Designed and manufactured in the UK by Tegiwa.
Compatibility: Aim Solo 2 and Solo 2 DL only.
Lap timer sold separately.
Manufacturer: Tegiwa
Material: ASA (Acrylonitrile Styrene Acrylate)
Surface Finish: Matte, factory-style finish
Visor Extension: 29mm beyond the screen face
Mounting Method: Tool-free, push-fit installation
Retention System: Integrated snap-fit beads, locating notch and rear corner recesses
Heat Resistance: High-temperature-resistant ASA construction
UV Resistance: UV-resistant material
How do I mount the Aim Solo 2 in my vehicle, and does it come with mounting accessories?
The Aim Solo 2 comes with a universal mounting bracket, with optional accessories such as a suction cup, u bolt, or roll cage bracket. All mounting options provide a stable and vibration-resistant mounting solution, ensuring accurate data collection during your sessions.
Can the Solo 2 be mounted on a motorcycle?
Yes, the Solo 2/2 DL can be securely mounted using compatible motorcycle mounting brackets. Choose from a range of popular motorcycle makes including Aprilia, BMW, Ducati, Honda, Kawasaki, Suzuki and Yamaha.
