AiM Solo USB-Download-Kabel
USB Cable Connection
Featuring USB Type-A to Type-C connectors, this cable allows a quick and reliable connection between various Aim Data Loggers with a USB-C connector and your PC, allowing fast data transfer and system configuration through Race Studio 3 software.
Why Choose the Aim USB Cable
The USB Type-A to Type-C Cable is the ideal solution for downloading logged data, providing the perfect compatibility and reliability expected from Aim. Fully compatible with Aim data logging systems supporting USB communication, it ensures a clean, direct link between your data logger and your PC for high-speed, accurate data analysis.
