Aim TC Gelbe Buchse auf 712 4-poliges Thermoelement-Patchkabel
Connect Your System
Aim Thermocouple Patch/Extension Leads are used to connect Aim Thermocouple Sensors, such as an EGT (Exhaust Gas Temperature) Sensor to an Aim TC Hub, EVO4 and EVO4S Data Loggers. It has a TC Yellow push-on connector on one end and a 4-pin 712 screw on connector on the other for a secure and reliable connection.
Why Choose the Aim Thermocouple Patch Lead
Available in multiple lengths (0.5m, 1m, 1.5m, 2m, 2.5m, and 3m), this Thermocouple Patch Lead allows you to easily monitor vehicle temperatures. Designed specifically for motorsport, the Aim TC Yellow Female to 712 4-Pin Thermocouple Patch Lead is a durable cable that will suit a variety of vehicle types and setups.
Gelbes TC-Patchkabel mit Buchse auf 712-Stecker
