Ducati 848, 1098, 1198 Solo 2 DL Plug & Play Cable mit 7 Pin Male 712 Connector
Choose Accessories
Ducati Motorcycle ECU Connection
The Ducati ECU Plug & Play Cable allows you to connect the Aim Data Loggers, such as the Solo 2 DL, ECULog or XLog, to the Ducati-specific connector. The Ducati ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Plug & Play Cable
The plug & play cable has been specifically designed for the following Ducati motorcycle models and years:
- Ducati Panigale V4 – From 2018
- Ducati Panigale V2 – From 2020
Example Data Protocols
Example data protocols sampled can include RPM, gear, wheel speed, throttle position, intake air temperature, battery voltage and many more. Refer to the user guide in the Downloads tab for a full protocol list.
Ducati Solo 2 DL Plug & Play Cable
