Direkt zum Inhalt
Suche
Suche Login Warenkorb 1
Warenkorb
Nur noch £32.85 fehlen, um kostenlosen Versand zu erhalten!
  • Link TWL 58/60 tooth trigger wheel for Link ECU trigger systems
    Link Trigger Wheel (TWL) 58/60 Tooth
    £67.15
    Entfernen
Sonderanweisung bestellen
Zwischensumme
£67.15
Warenkorb ansehen
Suche
Link Nissan 350ZLink N350X PlugIn ECU module for Nissan 350Z performance tuning
Link Nissan 350Z N350X PlugIn ECU module for vehicle engine management
Link Nissan 350Z N350X PlugIn ECU, plug-in engine control unit module by Link
N350X
Link Nissan 350ZLink - N350X PlugIn ECU
Verkaufspreis£1,165.50
Normaler Preis £1,295.00
  • Auf Facebook teilen
  • Auf WhatsApp teilen
  • Per E-Mail teilen
  • E-Mail Per E-Mail teilen
Verkaufspreis£1,165.50Normaler Preis £1,295.00
Easy to install. Affordable. Reliable
This ECU comes in its own enclosure, while the installation is a breeze with no alteration of the factory wiring loom required for the models listed below.
The N350X ECU is designed to suit the VQ35DE engine.
This ECU works with manual AND automatic transmissions.
ECU includes an onboard 4 bar or 7 bar MAP sensor.
Check the features tab for I/O expansion options
Highly recommended to fit an IAT sensor.
Suitable Applications:
2002 to 2006 Nissan 350Z (Fairlady Z Z33)
2003 to 2006 Nissan Skyline V35
2003 to 2006 Infinity G35
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
+5V Low Current +5V Supply
Aux 15 Auxiliary Output
Aux 14 Auxiliary Output
DI 8 Digital Input
DI 9 Digital Input
An Volt 8 Analog 0-5V input
Expansion connector 2
DI 11 Digital Input
Aux 16 Auxiliary Output
Aux 8 Auxiliary Output
  • G4X PlugIn ECU
  • Stickers
  • Support-Videos
  • Kontaktieren Sie uns
  • Werden Sie Botschafter
  • Reparaturen
  • Live-Chat & Support
