Direkt zum Inhalt
Suche
Suche Login Warenkorb 1
Warenkorb
Sie haben Anspruch auf kostenlose Lieferung.
  • Link Nissan S13Link NS13X PlugIn ECU module for Nissan S13
    Link Nissan S13Link - NS13X PlugIn ECU
    £1,246.50
    Entfernen
Sonderanweisung bestellen
Zwischensumme
£1,246.50
Warenkorb ansehen
Suche
Link BAL6 ballast resistor for ignition and injection systems, shown on a plain background
Link BAL6 ballast resistor for ignition and injection systems, shown on a white background
BAL6
Link Ballast Resistor (BAL6)
Verkaufspreis£85.00
Normaler Preis £100.00
  • Auf Facebook teilen
  • Auf WhatsApp teilen
  • Per E-Mail teilen
  • E-Mail Per E-Mail teilen
Verkaufspreis£85.00Normaler Preis £100.00
For use with low-impedance injectors. Compatible with injectors with impedance between 2 and 6 Ohms. Please contact us if you are planning on using injectors with an impedance of fewer than 2 ohms.
Includes set of 6 x 4.7ohm 25w resistors mounted to a heatsink. These are also sold in a set of 4.
Note that injector ballast resistors get quite hot at high injector duty cycles. These should stay mounted on the supplied heat sink and be bolted to the chassis.
  • 6 x 4.7 ohm 25w mounted to a heatsink
  • Support-Videos
  • Kontaktieren Sie uns
  • Werden Sie Botschafter
  • Reparaturen
  • Live-Chat & Support
