Direkt zum Inhalt
Suche
Suche Login Warenkorb 1
Warenkorb
Sie haben Anspruch auf kostenlose Lieferung.
  • AiM Solo 2 DL GPS and ECU car track day lap timer with cyan front display screen
    AiM Solo 2 DL GPS + ECU Car Track Day Lap Timer
    Title:
    Default Title #MWS Options 2611452794
    £1,465.00
    Entfernen
Sonderanweisung bestellen
Zwischensumme
£1,465.00
Warenkorb ansehen
Suche
Link BMWLink E36X PlugIn ECU for BMW E36 vehicles
Link BMWLink E36X PlugIn ECU for BMW vehicles
Link BMWLink E36X PlugIn ECU for BMW E36, plug-in engine control unit shown from above
E36X
Link BMWLink - E36X PlugIn ECU
£1,145.00
  • Auf Facebook teilen
  • Auf WhatsApp teilen
  • Per E-Mail teilen
  • E-Mail Per E-Mail teilen
£1,145.00
Link BMW Link - E36X ECU PlugIn ECU
This ECU is designed for the E36 M50TUB25 engine.
This ECU only works with the Engine Code M50TUB25 (Bosch ECU from the factory).
Works with manual & automatic transmissions.
Built-in 4 Bar MAP sensor or 7 Bar MAP sensor included.
Suitable Applications:
M50TUB25 engine with the Bosch M3.3.1 ECU from factory
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
Expansion connector - The following expansion connector inputs/outputs are provided:
TEMP3 Temperature sensor input
TEMP4 Temperature sensor input
VOLT4 Analog 0-5V input
VOLT5 Analog 0-5V input
DI8 Digital Input
DI7 Digital Input
+5V Low Current +5V Supply
GND Sensor Ground Only
*Please see the PC Link Help file for details regarding installing the Expansion Cable.
  • G4X PlugIn ECU
  • Stickers
  • Support-Videos
  • Kontaktieren Sie uns
  • Werden Sie Botschafter
  • Reparaturen
  • Live-Chat & Support
