This kit is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
Perfect for Touring, Circuit, Rally & More
Capture every detail, understand every lap, and find the time you’re leaving behind. The 84º SmartyCam 3 Dual, GPS09 and Race Studio 3 work together to give you a complete video and data analysis system, helping you turn every track session into an opportunity to improve your performance and go faster.
Why Choose the Aim Touring Car/Circuit Camera Kit
Combining the SmartyCam 3 Dual, GPS09 and Race Studio 3 software, you get more than just high-quality onboard footage, you get a complete video and data analysis system that allows you to see, understand and improve your driving. Capture multiple camera angles at 84º, record precise GPS data, analyse braking points, cornering speeds, racing lines and lap times, and identify exactly where you can gain an advantage. Whether you're attending track days, competing in club racing or looking to shave tenths off your next lap, this kit gives you the tools to learn from every session, make smarter adjustments and arrive at your next outing ready to go faster.
The Aim SmartyCam 3 Dual
The Aim SmartyCam 3 Dual is a high-performance onboard motorsport camera system designed for drivers who want more than just footage of their laps. Combining high-quality video recording with motorsport data integration, it allows you to review, analyse and improve your driving, making it ideal for track days, competitive racing and professional motorsport. With dual camera inputs, you can capture two different angles of your car simultaneously, using Picture-in-Picture functionality in Race Studio 3 to compare perspectives and gain a better understanding of your driving, vehicle behaviour and performance.
Motorsport Camera Features
Built for trackside practicality, the SmartyCam 3 Dual features automatic track recognition, 84º bullet camera lenses, 30 or 60 FPS recording, live video output for pit crew viewing, and efficient H.264 compression to maintain video quality without unnecessarily large files. Footage can be quickly downloaded and reviewed between sessions, while the weather-protected SD card housing and compatibility with wider Aim data logging systems, displays and sensors make it an ideal solution for drivers looking to combine video and telemetry into a powerful performance analysis package.
Precise GPS Tracking
The Aim GPS09 GPS Module is the perfect companion to the SmartyCam 3 Dual, adding precise GPS tracking, automatic lap timing and real-time performance data to your onboard footage. By accurately recording your vehicle’s position, speed, acceleration, lateral and longitudinal G-forces, it allows you to go beyond simply recording laps and start understanding exactly how you’re driving. With access to over 4,000 track layouts worldwide, automatic track recognition, split timing and predictive lap times, you can identify where you’re gaining or losing time and compare your performance lap by lap.
A Full Kit Solution
Paired with the SmartyCam 3 Dual, the GPS09 brings your video and performance data together to create a more powerful trackside analysis tool. Review your footage alongside speed, lap times, track position and cornering data to understand braking points, cornering behaviour and where improvements can be made. Whether you're attending track days, competing in circuit racing or tackling rally stages using Point-to-Point mode, the GPS09 transforms your SmartyCam footage into meaningful performance feedback, helping you make informed adjustments and improve with every session.
How to Improve Your Next Race
Race Studio 3 is a free, powerful data analysis software that turns your SmartyCam 3 Dual footage and GPS09 data into actionable insights to help you improve your driving. Synchronise your onboard footage with real-time GPS and performance data, compare laps, analyse braking points, cornering speeds, acceleration and racing lines, and identify exactly where you are gaining or losing time around the circuit. Rather than relying on memory alone, you can see precisely what happened on track and understand what is costing you lap time.
Compare your fastest laps, identify areas for improvement and use your data to make smarter decisions every time you head back out on track. Whether you're fine-tuning your braking, carrying more speed through corners or working towards greater consistency. Review your last session, find the time you’re leaving behind, and go into your next race with a plan to go faster.
Below Technical Specs
1. SmartyCam 3 Dual
2. GPS09 Roof Mount
3. Bullet Cameras
1. SmartyCam 3 Dual
  • Display Resolution: 2.4” 240 x 320 pixels
  • CMOS Sensor: Global shutter
  • Field Of View: 84°
  • Video Output: 3G-SDI
  • External Power: 9-15V
  • Auto Power ON/OFF: Yes
  • Body: Anodised aluminium
  • Bullet Cable Length: 2m or 4m options
Size
  • Bullet Camera: 24 diameter x 48.2mm
Weight
  • Main Unit: 800g
  • Bullet Camera: 45g
SKU: SM3-D
2. GPS09 Roof Mount
  • GPS: 25Hz
  • External Power: 5-15V
  • Inertial Platform: No
Available GPS Channels
  • Altitude
  • Latitude
  • Longitude
  • Sats Number
  • POS Accuracy
  • Speed Accuracy
  • GPS Lateral Acceleration
  • GPS Linear Acceleration
  • GPS Heading
  • GPS Yaw Rate
  • GPS Hour
  • GPS Min
  • GPS Sec
  • GPS Hundredths of a Second
  • Year
  • Month
  • Day
  • Week Number
  • ITOW
  • Unix Time
  • Dimensions: 53.2 x 64.8 x 19.7mm
  • Weight: 60.5g
SKU: GPS-CR-2
3. Bullet Cameras
  • Anodised black
  • Billet machined
  • Available in 67°, 87°, 120° lens
Microphone Connectors On SmartyCam
Pinouts
GPS09 pinout
SmartyCam 3 Dual Tech Sheet
SmartyCam 3 Dual User Guide
GPS09 Pinout
