BICMK
Super B Be In Charge-Überwachungskit
What Is The Be In Charge Monitoring Kit?
The Super B Be In Charge Monitoring Kit provides important information about the condition and usage of the battery, so you can easily detect possible issues.
Compatible Batteries
The standard battery monitoring kit is compatible with Nomia 12V210Ah / 12V340Ah, Nomada, Battery Interface Box and Battery Communication Interface. The Be In Charge Monitoring Kit Light has fewer components and is only compatible with Epsilon 12V100Ah / 12V150Ah batteries.
Chosen Super B Monitoring Kit
How do you download the "Be In Charge" software & app?
Super B provides a Be In Charge Software tool, which can be used to read out the internal BMS system. The software uses a CAN to USB converter to connect to the communication interface. The software is capable of reading out the actual status, like battery/cell voltages and temperature, but also statistical information. Be In Charge software can also be used to update the installed firmware of the Li-ion battery. The Be In Charge software and hardware are not part of the Li-ion battery scope of delivery. Super B also provides a Be In Charge App for mobile devices such as Android and iOS. The app can be found in the Google Play Store or Apple App Store.
