Upgrade your riding setup with one of the best motorcycle lap timers in the industry — the Solo 2 DL GPS lap timer. Display instant speed, timing splits, live data and delta lap times on a high-contrast display with an accuracy of up to two-hundredths of a second.
Why Choose the Motorcycle Solo 2 DL
Building on the features of the Aim Solo 2 model, the Solo 2 DL motorcycle lap timer connects directly to your bike’s ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and bike ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
On-Screen Delta Feedback
The Solo 2 DL has a sharp, high-contrast display which helps riders easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide track maps are available, the track day lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to ride, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Whether it's used for point-to-point runs or a closed-loop track, the Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Inertial Platform
The Solo 2 DL calculates, displays, and records lap times, sector times, position & vehicle speed, with a sampling rate of up to 25Hz, and 3D acceleration & gyro. This allows you to see your exact racing line, compare it to optimal lines for faster lap times, track the motorcycle's movements and provide detailed data on acceleration, braking, and cornering forces.
One of the many reasons that the Aim Solo 2 lap timer is regarded as one of the best GPS lap timers in the motorsport industry is due to its easy configuration and integration with Race Studio 3 software.
Mounting Options
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
  • Pushbuttons: Metallic
  • Solo 2 DL
  • Cable icon
    Power Cable with AC Adapter
  • Cable icon
    Your Chosen Connection Cable
Solo 2 DL Tech Sheet
Solo 2 DL User Guide
Videos
Overview
Load video: An in-depth review of the main features and functions of the Aim Solo 2 DL motorcycle lap timer.
