Second-Life Aim Solo 2 GPS Track Day Racing Lap Timer
The Most Precise & Easy Way To Get Lap Times
Upgrade your track day setup with one of the best motorsport lap timers in the industry — the Solo 2 GPS Lap Timer. Equipped with an integrated GPS, built-in gyro, user-friendly interface and compatibility with session performance analysis software, the Solo 2 provides precise lap times, delta times and detailed telemetry for amateur and professional racers to optimise their performance and achieve their racing goals.
Why Choose the Track Day Solo 2 GPS Lap Timer
The Track Day Solo 2 Lap Timer includes a high-precision GPS and receives data from GPS and GLONASS satellite constellations. This allows the device to display instant speed, timing splits, live data and predictive lap times on its high-contrast display with an accuracy of two-hundredths of a second to help drivers improve their performance on the track.
The improved GPS technology in the Solo 2 also provides better reliability from the predictive lap timing function so that you can see, in real time, how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication on whether you are quicker or slower.
Accurate Lap Times
The Solo 2 Lap Timer features a 100Hz 6-axis inertial platform to calculate, show and record lap times, sector times, position & vehicle speed, with a sampling rate of up to 25Hz, and 3D acceleration & gyro.
Predictive Lap Timing
- Best lap of the day
- Best lap of the session
- Previous lap
- User reference lap
The Solo 2 has a sharp, high-contrast display which helps drivers easily identify the data displayed on screen, as well as 8 different backlight colours.
Whether it's used for point-to-point runs for rallying or a closed-loop track, the Solo 2 allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Lap Times & Sector Times
The Solo 2 features an internal, high precision, 25Hz, 4-constellation GPS receiver and an internal database including information about thousands of tracks all over the world: just switched 'On,' it automatically recognises the track and gets the information about the starting line position and the time zone.
The precision of the calculated lap times is 1/100 of a second.
Extensive Track Database
The Solo 2 Lap Timer includes thousands of pre-loaded track maps worldwide, the lap timer automatically recognises your position on the track, recognises the start line, and starts sampling lap times every time you go past.
Whether it's used for circuit racing or performance tests, the Solo 2 allows you to create a new, temporary, or permanent track layout.
Mounting Options
A variety of Solo 2 mounts provides an easy installation for a wide range of vehicle types.
Solo 2
Wall Charger with AC Adapter
Power Cable with Lighter Socket
Videos
Overview
Walkthrough
Race Studio
How do I mount the Aim Solo 2 in my vehicle, and does it come with mounting accessories?
The Aim Solo 2 comes with a universal mounting bracket, with optional accessories such as a suction cup, u bolt, or roll cage bracket. All mounting options provide a stable and vibration-resistant mounting solution, ensuring accurate data collection during your sessions.
How do I customise the display and LED shift lights on the Aim Solo 2?
Customising the display and LED shift lights on the Aim Solo 2 is straightforward. You can adjust settings directly on the device through its user interface. To do this:
- Navigate to the "Settings" menu using the side buttons.
- From there, you can choose various display options, such as switching between lap time, predictive lap timing, speed, and other data fields.
- To customise the LED shift lights, go to the "Shift Light" setting, where you can set specific RPM thresholds for when the LEDs light up, or you can adjust their brightness and colour. These settings help you optimise performance by providing visual cues while driving.
For more detailed customisation, you can also make changes through the Race Studio 3 software, where additional options like screen layouts are available.
| Specs |
Aim Solo 2 DL
Aim Solo 2
