AiM SmartyCam HD 2.1 & SmartyCam 3 U Bolt Mount Offroad
SKU: SM-UB-MX-X90KSTP00
- Precio regular
- £60.00
- Precio regular
- Precio de venta
- £60.00
- Precio unitario
- por
+ IVA (Solo Reino Unido)
The SmartyCam can be installed using the U bolt mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Secure mounting for SmartyCam | Ball & socket system |
Suitable for 0.5 to 1.2" | For SmartyCam HD 2.1 & SmartyCam 3 |
The AiM SmartyCam U Bolt mount allows you to mount your SmartyCam to your car/motorcycle.
The mount has been designed to mount to a roll bar, railings, or tubes that have a diameter of between 0.5 to 1.5 inches. The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
The mount is adjustable, once you have the camera in the optimal position to capture the best footage you just need to tighten the leaver to secure the camera in place.
U Bolt Mount
Securely attaches to any roll bar, railing or tube with a diameter of 0.5 to 1.2 inches.
- 1 U-Bolt and straps
- 160mm single ball arm
- 1 Ball head
- 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
The SmartyCam can be installed using the U bolt mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.Key Features :
The AiM SmartyCam U Bolt mount allows you to mount your SmartyCam to your car/motorcycle.The mount has been designed to mount to a roll bar, railings, or tubes that have a diameter of between 0.5 to 1.5 inches. The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
U Bolt Mount
Includes a rubber insert and lock nuts for a secure fit.A solid ball and socket type system provides an adjustable and very strong mounting.
- 1 Ball head
