Aim Cable de alimentación externo Solo 2 DL CAN/RS232 de 2 m
Connect Your System
The Aim CAN/RS232 External Power Cable is used to connect the Aim Solo 2 DL to your vehicle's ECU wiring. The full length of the cable is 2m, so it will fit your vehicle well but still remain compact in your Aim setup.
Why Choose the Aim CAN/RS232 External Power Cable
The Aim CAN/RS232 External Power Cable can be used for thousands of supported ECUs, so you can track your laps and make improvements. The cable length is a convenient size for any vehicle, providing smooth communication and reliable power to your Solo 2 DL Lap Timer for optimum performance during track days.
Note: This is one of the connection cables available for the Solo 2 DL. Others are the OBDII and the RPM cables.
Solo 2 DL CAN/RS232 External Power Cable
