1 de 3
AiM Solo 2 / Solo 2 DL 5 Pin 2M External Motorcycle Power Lead Unterminated
SKU: SOLO2-EXP-MC
Precio regular
£54.00
Precio regular
Precio de venta
£54.00
The AiM external power lead fits the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
5 pin - 712 male binder connection Unterminated end with 2 wires
 Suitable for Solo 2 & Solo 2 DL
External Power Cable
The AiM external power cable fits the AiM Solo 2 and Solo 2 DL GPS Lap Timers. It features a 5-pin 712 male binder connection, which goes into the Solo2/Solo 2 DL.
The un-terminated wires allow you to connect to an external battery.
This allows Solo 2 and Solo 2 DL GPS Lap Timers to have longer running times.
  • 5 pin - 712 male binder connection
  • Unterminated end with 2 wires: 12V+ & Ground
  • 2m length cable
  • Solo 2 / Solo 2 DL External Power Lead
The AiM external power cable fits the AiM Solo 2 and Solo 2 DL GPS Lap Timers. It features a 5-pin 712 male binder connection, which goes into the Solo2/Solo 2 DL. The un-terminated wires allow you to connect to an external battery. This allows Solo 2 and Solo 2 DL GPS Lap Timers to have longer running times.
  • 2m length cable
