Mychron 6 GPS Lap Timer
Choose Accessories
The Aim MyChron 6 is our GPS lap timer specifically crafted for karting. Combining 30 years of experience with advanced technology, the MyChron 6 offers precise lap timing and advanced data analysis for both amateur and professional racers.
Why Choose the MyChron 6 GPS Lap Timer
The MyChron 6 GPS lap timer revolutionises how drivers and teams monitor and analyse performance on track. Due to its highly accurate 25Hz GPS tracking, large screen displaying delta times and comprehensive data logging capabilities, the MyChron 6 lap timer provides detailed performance analysis from split times and overall delta time, racing lines, cornering speeds and braking points.
Note: The MyChron 6 is compatible with the most common heart rate monitors on the market.
Advanced Display
The MyChron 6 features a wide graphical display, ensuring excellent readability. Brightness and contrast are automatically adjusted to maintain ideal visibility in all lighting conditions, and this allows drivers to clearly monitor not only their best vs current sector times, but also their heart rate, delta, delta bar graphs and more, allowing real time adjustments to be made, improving lap performance.
An exclusive on-screen delta bar animation showcases instant graphical feedback on your live performance, showing how your current timing compares to your best.
LED & Alarms System
Automatic Track Recognition
The MyChron 6 lap timer features an internal database including information about the track: just switched ON, it automatically recognises the track and gets the information about the Starting Line Position and the Time Zone. The precision of the calculated lap times is 1/100 of a second.
Available Sensors
The MyChron 6 GPS lap timer uses a range of sensors to monitor engine performance and prevent damage. Choose from:
- Cylinder Head Temperature (CHT) Sensor: Tracks the engine’s combustion temperature, helping avoid overheating, especially when tuning.
- Exhaust Gas Temperature (EGT) Sensors: M5 and T12 EGT sensors measure exhaust temperatures to fine-tune the air/fuel mix, vital for performance and engine safety.
- Water Temperature Sensors: Available in M10 (for Rotax, X30, OK) and M5 thread sizes, these sensors monitor coolant temperature to ensure the engine runs within its optimal range, with size options to suit different engines or fittings.
Upgrade your MyChron 6 lap timer with sensors and expansions for complete data control; OTK non-contact brake, throttle, and brake pressure kits track pedal travel and force, while wheel speed, water temp, CHT, EGT, and steering angle sensors deliver precise performance metrics.
The Data Hub multiplies CAN connections, with powered and non-powered options, with power coming from the 20-hour MyChron Lithium Battery, or a direct 12V external lead.
MyChron 6 Lap Timer
USB-C Cable
