1 de 5
Peugeot Sport 208 Rally4 Aim SmartyCam 3 Corsa Kit from 2020
SKU: peugeot-SM3
Precio regular
£1,150.00
Precio regular
Precio de venta
£1,150.00
Compact, Advanced, Precise
Enhance your Peugeot Sport 208 Rally4's performance with the AiM SmartyCam 3 Corsa Kit, specifically designed for models from 2020.
The NEW SmartyCam 3 Corsa saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Corsa automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times.
hyundai i20 Rally2 BC3n
Supported Models and years
  • Peugeot Sport 208 Rally4
    from 2020
Peugeot Sport 208 Rally4 features a bus communication protocol based on CAN that can be reached through the 4 ways ITT Cannon female connector labelled GIP and located on the central tunnel.
smartycam icon
smartycam icon
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
smartycam icon
Quality
smartycam icon
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU direct to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
smartycam icon
Higher Storage Capacity
Generic HD cameras focus too much on pixel numbers resulting in large file sizes. The SmartyCam 3 footage has the same quality as other FHD cameras with smaller files due to H.264 compression system parameters being optimised to a perfect balance between video quality and file size. Choose between three file quality levels: O recording = 4GB (High Quality), 2GB (Normal Quality) or 1.5GB (Lower quality).
SD cards sold separately.
smartycam icon
The SmartyCam 3 Corsa Kit seamlessly integrates with the Peugeot Sport 208 Rally4's ECU, providing real time data overlays for enhanced performance analysis. The SmartyCam 3 Corsa can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
smartycam icon
Upgrade your Peugeot Sport 208 Rally4 with the AiM SmartyCam 3 Corsa Kit today and experience unparalleled data insights for yourself!
  • Display resolution: 128 x 128 pixels
  • CMOS sensor: Global Shutter
  • Field of view: 67°, 84°
  • External power: 9-15 Volt
  • Connectors: 3 Binder 712 female 1 USB-C
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Dimensions: 102.2 x 63 x 46.5 mm
  • Weight: 280g, battery included
  • Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Peugeot Sport 208 Rally4 drivers
smarty cam 3 sport connectors
smartycam 3 corsa pinout
Channels received by AiM devices configured with Peugeot Sport 208 Rally4 protocol are:
Channel Name Function
RPM Engine RPM
Car Speed Vehicle Speed
Wheel Speed FL Wheel Speed front left
Wheel Speed FR Wheel speed front right
Wheel Speed RL Wheel speed rear left
Wheel Speed RR Wheel speed rear right
rPedal Throttle pedal position
PBrake Front Brake pressure front
PBrake Rear Brake pressure rear
aSteering Steering wheel angle
Gear Engaged gear
Water Temp Engine coolant temperature
Oil Temp Engine oil temperature
Air Temp Intake air temperature
Ambient Temp AMbient temperature
Oil Press Engine oil pressure
Boost Boost pressure
  • SmartyCam 3 Corsa
  • USB-C Cable
  • 2m CAN Cable
  • 712 5 Pin Male
  • 4M Can Bus + Integrated 3.5 Female Jack For External Microphone Harness
    from 2020
smartycam icon
smartycam icon
Standalone Feature
smartycam icon
Quality
smartycam icon
Anatomy
The SmartyCam 3 Corsa contains a rechargeable lithium battery confined inside its 102.2x63x46.5mm body, and using its connectors - 3 Binder 712 female + 1 USB-C - slots right into the back of your dashboard. Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU direct to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
smartycam icon
smartycam icon
smartycam icon
Technical Specifications
Peugeot Sport 208 Rally4 Protocol
RPM Engine RPM
Gear Engaged gear
What's In The Box
  • SmartyCam 3 Corsa
  • USB-C Cable
  • 2m CAN Cable
  • 712 5 Pin Male
