Data Logging Steering Wheel
The Aim GT320/GT350 sim racing Formula steering wheel 4 (SW4) is one of our most advanced sim racing steering wheels to date. It features an internal data logger with full configuration options, removable grips, rotary switches, and seamless compatibility with sim telemetry and expansion hardware.
Why Choose the GT320/350 Sim Racing Steering Wheel
The Aim Formula steering wheel GT320/GT350 is designed for sim racers who want a larger format wheel, making it ideal for GT and closed-cockpit style racing rigs. The internal data logger is fully configurable and works across a wide variety of racing simulators.
It has been developed to acquire and display telemetry data streamed from your sim racing software, including parameters such as RPM, gear, speed, throttle, brake, lap times, and more.
Our Formula steering wheels are available in multiple sizes (270, 280, GT320 & GT350). The difference between the Formula SW4 GT320 and GT350 is the overall size: the GT350 is 30mm larger to suit different cockpit layouts and driver preferences.
Connecting the Aim GT320/GT350 Formula steering wheel to your racing simulator is quick and straightforward. Telemetry is received directly from the sim software, removing the need for analogue sensors or physical ECU integration. Depending on the racing sim you use, available data typically includes RPM, throttle and brake inputs, gear, speed, fuel, tyre data, lap and split times, and more.
With CAN output, the Formula steering wheel can also communicate with other Aim sim racing devices and expansions, broadening your setup’s telemetry and control options.
Display & Push Buttons
The GT320/GT350 Formula sim racing steering wheel has a high-contrast 5" TFT display that is fully configurable and glare-resistant. An ambient light sensor ensures the display remains easy to read in any lighting conditions.
The Formula steering wheel also features 10 push buttons and 3 rotary switches, all backlit with RGB LEDs for enhanced usability in your sim racing rig.
Flexible Alarms
The Aim GT320/GT350 sim racing Formula steering wheel has 8 configurable RGB shift light LEDs and 4 configurable RGB alarm LEDs. You can set colours, flashing behaviour, and priorities, and display on-screen messages alongside them.
The integrated shift lights also support advanced multi-colour patterns that can be customised to your preferences, even with different profiles for each gear if desired.
There is a wide selection of accessories available to get the most out of your sim racing steering wheel:
  • Clutch Paddles: Add left and/or right clutch paddles directly from the options at the top of the page to suit your driving style.
  • GPS Module: When used in sim environments, the GPS Module enables lap time calculation and virtual track position analysis, with a database of thousands of circuits available.
  • CAN Connections: 3
  • ECU Connection: CAN
  • ECU Compatibility: 1,000+ industry-leading ECUs
  • Shift Lights: 8 configurable RGB LEDs
  • Ambient Light Sensor: Yes
  • Expansion CAN Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam, RIO Module, GS-Dash, Memory Module
  • Connectors: 1 Deutsch Autosport 22-pin male connector
  • Power Consumption: 500mA
  • Internal Memory: 4GB
  • Push Buttons: 10 push buttons & 3 rotary switches (all with RGB backlights)
  • Display: 5" TFT
  • Contrast: 800:1
  • Brightness: 800 cd/m2 - 1,200 Lumen
  • GT320 Dimensions: 320 x 183.5 x 42.5mm
  • GT350 Dimensions: 350 x 183.5 x 42.5mm
  • Weight: 2,600g
SKU: FSW4
Aim SW4 GT320/GT350 Formula Steering Wheel Diagram
GT320 Tech Sheet
GT350 Tech Sheet
