Advanced 10” Dash Display
The MXT Strada with race icons is one of the most widely used dash displays on tracks around the world. The MXT 1.3 Strada has a 10" colour TFT display that offers a great visual impact. You can configure the dash to show all the information coming from the ECU, analogue/digital inputs, predefined math channels and an optional GPS Module.
The MXT Strada 10 inch Display integrated into a car dashboard on a racetrack
Why Choose the MXT 1.3 Strada 10” Dash Display
The MXT Strada Display is an HD digital display, designed for motorsport drivers who need essential data visibility while on the track or road. The dashboard is tailored to show real time data such as speed, RPM and temperatures, but doesn't include data logging functionalities natively.
The MXT 1.3 Strada is available with a choice of connections. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the car's ECU or OBDII port or directly to the ECU through the CAN channel.
Digital Outputs
The MXT 1.3 Strada features 2x 1A-max digital outputs configurable to be activated/deactivated depending on the value of the analogue/digital inputs or on the impulses coming from the car's ECU. This allows you to automatically run external systems, such as switching on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.
Carica il video: Delta times LED display feedback on the MXT 10 inch Strada Display
Carica il video: Integrated shift light array interface and customisable alarms for the MX Strada Series
Display with Race Icons
The MXT 1.3 Strada has a 10" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels. Race icons allow you to apply conditions to the LED icons.
Carica il video: Pre-configured dash display screens for the MX Strada Series.
Pre-Configured Pages
The MXT 1.3 Strada shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • Digital Inputs: 4-speed input, lap signal, coil RPM input
  • Digital Outputs: 2 (1 Amp max)
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Connectors: 2 Autosport connectors & 1 binder connector
  • Power Consumption: 450mA
  • Display: 10" TFT
  • Resolution: 1,280 x 480 pixels
  • Contrast: 1,100:1
  • Brightness: 800cd/m² - 1,200 Lumen
  • Weight: 1,100g
  • IP67
SKU: MXT
MXT Strada Display technical diagram
MXT Strada User Guide
MXT Strada Tech Sheet
What does the MXT Strada do?
The Aim MXT Strada is a digital dash display that can be configured to show real time information from the car's ECU, analogue/digital inputs, predefined math channels and an optional GPS Module. It provides crucial information like speed, RPM, water temperature, and oil pressure on a high-contrast TFT screen.
What size is the MXT display?
The MXT features a 10", 1,280 x 480 pixel resolution display, making it the largest display in the MX Strada series.
What alarms can be set on the MXT Strada?
The MXT Strada comes with 6 customisable RGB LEDs, which are determined by inputs from the car's ECU or other sensors. The MXT Strada with race icons can be configured with alarms for gear position, lap time improvement, throttle position, low fuel, low oil pressure, low oil level and other customised alarms that have been set.
What are the best applications for the MXT Strada with race icons?
The MXT Strada with race icons is best suited to various motorsport setups, including track day cars, kit cars & competitive race cars.
What are the differences between the MXT logger and the MXT Strada?
The main difference between the MXT logger and the MXT Strada display is that the logger version has a built-in data logger. However, a Strada Logger can be purchased for the MXT Strada, which records data to an SD card. The MXT logger also has 2 digital outputs, whereas the Strada only has 1. For a full comparison of the MX Strada Series, take a look at the comparison tab.
How do I display gear information on my MXT Strada?
Selected gear information can be sourced by gear potentiometer, ECU stream message or it can be calculated in real time by the MXT Strada through speed and RPM. Each mode requires a specific gear configuration.
How do you switch between pages on the Aim MXT Strada?
To switch pages on the Aim MXT Strada, first open our free Race Studio 3 software and then select the Page Configuration to customise each page. After choosing your selections, save your configurations and press the ">>" push button on the side of the device to switch between your pages.
How do I connect & configure my SmartyCam with MXT Strada?
To connect and configure your SmartyCam with MXT Strada, you need to connect the devices, set up the configuration in Race Studio 3, and then transmit the configuration to the device. First, ensure your SmartyCam has power and a formatted SD card. Next, launch Race Studio 3 on your PC, which will detect the devices. Then, go to the "Configurations" page to create a new configuration or edit an existing one and add the "SmartyCam Stream" layer. In this layer, you will associate the necessary functions with the channels and transmit the configuration to the device.
How do I connect my MXT Strada to my car’s engine control unit (ECU)?
How do I connect my MXT Strada to the car’s OBDII connector?
Use a dedicated OBDII wiring harness and configure the MXT Strada with Race Studio 3. The process involves a physical connection followed by software setup to identify your car's specific ECU protocol. More information can be found here.
MXT Strada
MXG Strada
MXP Strada
MXS Strada
  • 10” TFT display
  • 10 shift light RGB LEDs
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 7" TFT display
  • CAN output
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 6" TFT display
  • CAN output
  • 5 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 5" TFT display
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • Weight: 1,100g
  • Weight: 950g
  • Weight: 590g
  • Weight: 480g
  • IP67
  • MXT Strada Dash
  • 14-Pin Standard Wiring
  • MXG Strada Dash
  • MXP Strada Dash
  • MXS Strada Dash
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Second CAN: Yes
  • Power Consumption: 400mA
  • Second CAN: Yes
  • Second CAN: Yes
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Display: 7" TFT
  • Contrast: 1000:1
  • Display: 6" TFT
  • Display: 5" TFT
