Advanced Power Distribution Module
The Aim PDM08 is an 8-channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions.
Aim PDM08 Power Distribution Module
Why Choose the Aim PDM08
The Aim PDM08 is available on its own or with a choice of 5", 6" or 10" dash displays. It's also capable of receiving data from the vehicle ECU, and even comes with a data logger and optional GPS module for lap timing and track mapping.
With a total continuous max current of 100A, each of the outputs provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, the number of fault retries and the time between the retries is user definable. All outputs can be configured as PWM's for a soft start/stop. All of the PDM circuits can be set up and monitored via the Race Studio 3 software.
PDM08 Data Management
The PDM08 can receive and record data from the following sources:
  • Digital/analogue inputs
  • Internal 9-axis IMU
  • GPS: Lap time and position
  • Expansion Modules
  • Push buttons from RIO02 (Remote Input Output module) or any commercial CAN keypad
  • PDM Outputs: Currents and status of each channel individually
  • Other user-defined math channels
3 variations of PDM Dash Display in 5, 6 and 10-inch
PDM Dash Displays
The PDM displays are TFT dash displays suitable for replacing all of the dashboard gauges and warning lamps.
The displays are available in 5", 6" or 10" versions and with "Road" or "Race" icons. Road and Race icons allow you to apply conditions to the LED icons, such as fuel, engine, oil, lights, indication and more. All versions have full user-configurable displays and offer a range of layouts.
GPS Options
The GPS09 module option provides easy lap timing and lap position for track mapping. The PDM08 has over 4,000 racetracks in the database, so once you arrive at the track, the system already knows the timing points so that you can get on with the driving.
The GPS09 module is available with various lead lengths to suit different applications and with cable entry from underneath (roof version) or the side.
The Aim CAN Expansion Keypad render
Aim CAN Expansion Keypads
Optional Wiring Solutions
  • LEDs: 8 RGB LEDs, 1 PDM ON & 1 PDM STS (status)
  • Inputs: 6 fully configurable (max 500Hz each), pullup, pulldown & analogue/digital
  • Speed Inputs: 2
  • Lin Bus: 1
  • CAN Connections: 3
  • Internal Platform: 3-axis ±5G accelerometer, 3-axis gyro & 3-axis magnetometer
  • Internal Memory: 4GB
  • External Modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam, Formula Steering Wheel, Memory Module, Remote I/O Push-Button Module
  • External Analogue Camera Input: No
  • Connectors: 1 AMP connector, 1 Amphenol SurLok connector & 1 Rosenberger connector
  • Remote Display Connection: 1 Aim stream output
  • Body: Anodised aluminium
Power Outputs
  • 1 with a series diode rated up to 20A
  • 1 rated up to 25A
  • 6 rated up to 15A
  • Protected For: over-voltage, under-voltage, over-current, over-temperature
  • Total Max Current: 100A
  • Dimensions: 161 x 100.6 x 50.6mm
  • Weight: 370g
SKU: PDM-8
  • PDM08
  • SurLok Power Connector
  • Black 35-Pin Plug & Pins
  • CAN Expansion Cable
  • Download Cable
PDM08 User Guide
PDM08 Tech Sheet
What does a PDM do?
At Aim, we have 2 PDM modules to suit different vehicle setups: PDM32, which has 32 output channels for more complex setups and PDM08, which has 8 output channels for simpler or compact setups. The 'best' PDM depends on how many outputs you need and the size of the setup.
Can PDMs be used on road cars?
Absolutely! Although PDMs are primarily used in motorsport applications, they can be used to replace traditional relay and fuse setups. In fact, PDMs can work with wipers, indicators and more.
The PDM08 has 6 analogue or digital inputs and 2 speed. You can add a CAN Keyboard, giving between 4 and 15 buttons, wireless wheels giving up to 8 buttons and 2 rotary inputs, and RIO modules, which can give 8 high or low inputs and 11 low-only inputs.
Can indicators be set to auto-cancel in a road-legal car?
Yes, you can use the built-in logger roll, pitch and yaw to do this. The yaw increases when turning right and decreases when turning left. If you want the right indicator to cancel, you can use a function with yaw less than -5, and to cancel left turn, the function would have a yaw greater than 5.
If front wipers are on, can rear wipers come on when reverse is selected?
Absolutely! If the front wipers are on, you can configure the PDM to activate when reverse is selected to have front and rear wipers working at the same time. This will need to be configured in the PDM.
  • 6 Analogue Digital Inputs
  • 8 RGB LEDs
  • 2 Speed Inputs
  • Power Outputs
  • GPS Lap Timing (Optional)
  • Data Logging
  • 8 Analogue Digital Inputs
  • 32 RGB LEDs
  • 2 Speed Inputs
  • 4 Digital Inputs
  • Data Logging
  • 6 Analogue Inputs
  • 8 RGB LEDs
  • 8 Power Outputs
  • Power Module Expansion
  • 8 Analogue Inputs
  • 32 RGB LEDs
  • 32 Power Outputs
  • Weight: 370g
  • Dimensions: 234.5 x 94.6 x 49.5mm
  • Weight: 761g
  • Weight: 370g
  • Dimensions: 234.4 x 95.1 x 49mm
  • Weight: 740g
  • PDM08 Unit
  • Download Cable
  • PDM32 Unit
  • Grey & Black 35-Pin Plug & 70 Gold Pins
  • Download Cable
  • EPM08 Unit
  • EPM32 Unit
  • Inputs: 6 fully configurable (max 500Hz each), pullup, pulldown & analogue/digital, 2 speed inputs
  • Power Outputs:
  • 1 with serie diode rated up to 20A
  • 1 rated up to 25A
  • 6 rated up to 15A
  • Protected for: over voltage, under voltage, over current, over temperature
  • All outputs have internal freewheeling diode
  • Total max current: 100A
  • Lin Bus: 1
  • LEDs: 32 RGB LEDs, 1 PDM ON & 1 PDM STS (status)
  • Inputs: 14 fully configurable (max 500Hz each) - 8 analogue/digital, 4 digital inputs, 2 speed inputs
  • Power Outputs:
  • 4 rated up to 20A
  • 12 rated up to 15A
  • 12 rated up to 10A
  • 4 rated up to 35A
  • Total max current: 120A
  • Lin Bus: 1
  • External Analogue Camera Input: 2
  • Connectors: 2 AMP connector, 2 binder connectors, 1 Amphenol SurLok connector & 1 Rosenberger connector
  • LEDs: 8 RGB LEDs + 1 EPM ON + 1 EPM STS (status)
  • Inputs: 6 fully configurable analogue inputs (0-5V; 0-12V) recorded at max 500Hz each, pullup/pulldown digital inputs
  • Power Outputs:
  • 1 rated up to 25A
  • 6 rated up to 15A
  • Protected for: over voltage, under voltage, short circuit, over current and over temperature
  • Connectors: 1 AMP connector + 1 Amphenol SurLok connector
  • LEDs: 32 RGB LEDs + 1 EPM ON + 1 EPM STS (status)
  • Inputs: 12 analogue inputs recorded at max 500Hz each (8 configurable as analogue or digital, 4 digital only), pullup/pulldown digital inputs
  • Power Outputs:
  • 3 rated up to 20A
  • 4 rated up to 35A
  • Total Max Current: 120A
  • Connectors: 2 AMP connectors + 1 Amphenol SurLok connector
  • Displays sold separately
