Upgrade your powerboat setup with one of the best powerboat lap timers in the industry — the Solo 2 DL GPS lap timer. Display instant speed, timing splits, live data and delta lap times on a high-contrast display with an accuracy of up to two-hundredths of a second.
See your exact sailing line, compare it to optimal lines for faster times, track your boat’s movements and provide detailed data from bow to stern. Do all of this and more with direct data logging for instant or post-race analysis with all your logged performance data.
Why Choose the Powerboat Solo 2 DL
Building on the features of the Aim Solo 2 model, the Solo 2 DL powerboat lap timer connects directly to your boat to record vital data, without the need for complex wiring. Compatible with a wide range of motorsport applications and ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
Solo 2 DL track recognition
On-Screen Delta Feedback
The Solo 2 DL has a sharp, high-contrast display which helps you to easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide maps are available, the lap timer automatically recognises your position as soon as it's switched on. Once you go, it automatically recognises the start line coordinates and starts sampling lap times every time you go past.
The Solo 2 DL allows you to create a new temporary or permanent map layout too. Even if there is no map already, the device will create one for you.
Inertial Platform
Mounting Options
To take your data one step further, the Aim Solo 2 DL powerboat lap timer seamlessly connects to Aim SmartyCams and a variety of vehicle sensors to increase your data performance and enhance your analysis with the added visuals and overlays, as well as additional sensor information.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SKU: SOLO2-k2
Solo 2 DL pinout
  • Solo 2 DL front view
    Solo 2 DL
  • Cable icon
    Wall Charger with AC Adapter
  • Cable icon
    Your Chosen Connection Cable
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
Videos
Overview
動画を読み込むAn in-depth review of the main features and functions of the Aim Solo 2 DL powerboat lap timer.
Aim Solo 2 DL
Aim Solo 2
  • 4GB Internal Memory
  • Automatic Track Recognition
  • Integrated GPS
  • Ten Configurable RGB LEDs
  • Wi-fi Connectability
  • GLONASS Receiver
  • Direct ECU Data Logging
  • Predictive Lap Timing
  • Choice of Connection
  • Integrated GPS
  • Graphical Display
  • Solo 2 DL
  • Choice of connection Cable
  • Solo 2
  • GPS: 25Hz
  • Memory: 4GB
  • GPS: 25Hz
  • Memory: 4GB
