セカンドライフ Aim 配電モジュール PDM08
セカンドライフ
Advanced Power Distribution Module
The Aim PDM08 is an 8-channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions.
Why Choose the Aim PDM08
The Aim PDM08 is available on its own or with a choice of 5", 6" or 10" dash displays. It's also capable of receiving data from the vehicle ECU, and even comes with a data logger and optional GPS module for lap timing and track mapping.
With a total continuous max current of 100A, each of the outputs provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, the number of fault retries and the time between the retries is user definable. All outputs can be configured as PWM's for a soft start/stop. All of the PDM circuits can be set up and monitored via the Race Studio 3 software.
PDM08 Data Management
The PDM08 can receive and record data from the following sources:
- ECU: Over 1,000 protocols available
- Digital/analogue inputs
- Internal 9-axis IMU
- GPS: Lap time and position
- Expansion Modules
- Push buttons from RIO02 (Remote Input Output module) or any commercial CAN keypad
- PDM Outputs: Currents and status of each channel individually
- Other user-defined math channels
PDM Dash Displays
The PDM displays are TFT dash displays suitable for replacing all of the dashboard gauges and warning lamps.
The displays are available in 5", 6" or 10" versions and with "Road" or "Race" icons. Road and Race icons allow you to apply conditions to the LED icons, such as fuel, engine, oil, lights, indication and more. All versions have full user-configurable displays and offer a range of layouts.
GPS Options
The GPS09 module option provides easy lap timing and lap position for track mapping. The PDM08 has over 4,000 racetracks in the database, so once you arrive at the track, the system already knows the timing points so that you can get on with the driving.
The GPS09 module is available with various lead lengths to suit different applications and with cable entry from underneath (roof version) or the side.
Aim CAN Expansion Keypads
Optional Wiring Solutions
PDM08
SurLok Power Connector
Black 35-Pin Plug & Pins
CAN Expansion Cable
Download Cable
What does a PDM do?
At Aim, we have 2 PDM modules to suit different vehicle setups: PDM32, which has 32 output channels for more complex setups and PDM08, which has 8 output channels for simpler or compact setups. The 'best' PDM depends on how many outputs you need and the size of the setup.
Can PDMs be used on road cars?
Absolutely! Although PDMs are primarily used in motorsport applications, they can be used to replace traditional relay and fuse setups. In fact, PDMs can work with wipers, indicators and more.
The PDM08 has 6 analogue or digital inputs and 2 speed. You can add a CAN Keyboard, giving between 4 and 15 buttons, wireless wheels giving up to 8 buttons and 2 rotary inputs, and RIO modules, which can give 8 high or low inputs and 11 low-only inputs.
Can indicators be set to auto-cancel in a road-legal car?
Yes, you can use the built-in logger roll, pitch and yaw to do this. The yaw increases when turning right and decreases when turning left. If you want the right indicator to cancel, you can use a function with yaw less than -5, and to cancel left turn, the function would have a yaw greater than 5.
If front wipers are on, can rear wipers come on when reverse is selected?
Absolutely! If the front wipers are on, you can configure the PDM to activate when reverse is selected to have front and rear wipers working at the same time. This will need to be configured in the PDM.
| Specs |
PDM08
PDM32
EPM08
EPM32
