Compact PDM Display
The 5" PDM display with road icons is one of the most widely used PDM displays on roads around the world. Its compact size makes it suitable for use as a replacement unit for those supplied with the Aim PDM kits or an upgrade for PDM kits that do not include a dash display.
Why Choose the 5” PDM Display
The 5" PDM display is a TFT dash display suitable for replacing all of the dashboard gauges and warning lamps. The displays are available in 5", 6" or 10" versions and with "Road" or "Race" icons. All versions have full user-configurable displays and offer a range of layouts.
Please Note: The 5" dash display is ONLY for use with Aim PDM kits and can not be used as a stand-alone dash display.
Display with Road Icons
The dash has a 5" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.
Aim 5" TFT Dash Display with Road Icons for PDM08/PDM32
Add extra devices to your system to give additional data to improve your driving performance, such as a GPS Module, TC Hub, SmartyCams, LCU-One S Lambda Controller, Formula Steering Wheels, TPMS System, Keypads and more.
The 5" road display also doubles up as a reversing mirror using a separately available camera; ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. The camera is sold separately. Please Note: You will require a PDM32 for this to work.
  • Ambient Light Sensor: Yes
  • Body: Anodised aluminium
  • Power Consumption: 400mA
  • Display: 5" TFT
  • Contrast: 600:1
  • Dimensions: 169.4 x 97 x 34.3mm
  • Weight: 530g
SKU: DISPLAY-5-I
5" PDM Display Tech Sheet
PDM08 User Guide
PDM08 Tech Sheet
PDM32 User Guide
PDM32 Tech Sheet
