Steering Angle Rotary Sensor
The Aim Steering Angle Sensor Kit is suitable for use with Aim loggers, displays and display loggers. It comes with a bracket for easy installation and is ideal for various 10 revolution motorsport car & bike setups.
Why Choose the Steering Angle Rotary Potentiometer
The Steering Angle Rotary Potentiometer measures and records the driver’s steering input using a sensor (rotating potentiometer) to measure the displacement between two points. Using the Steering Angle Sensor, you can see where time is being lost due to steering angle; too much or too little at each corner.
Steering Angle Rotary Sensor Connections
The Car & Bike Steering Angle Sensor is available with or without a 719-719 or 712-719 male to female 4-pin patch lead, which is required to connect the sensor to any Aim logger, dash display and display logger. For most setups, you will need the 719-719 patch lead to connect to logger harnesses that have 719 connectors, which are available in various lengths from 0.5 to 4 metres. If you're connecting to loggers such as the EVO Series or Channel Expansion, you will need the 712-719 patch lead.
Steering Potentiometer Electrical Characteristics
  • Nominal Resistance: 10kΩ
  • Tolerance on the Resistance Value: ±5%
  • Precision (%): 0.030
Steering Potentiometer Mechanical Characteristics
  • Mechanical Displacement: 1800° for 5 laps, 3600° for 10 laps
  • Temperature Working Range: -55/+125°C
  • Power Consumption: 5µA
  • 4-pin binder 719 male connector
  • Cable Length: 30cm
SKU: S-SA-X05SNST10G
Part Number: X05SNST10G
  • 10G Steering Potentiometer
  • Pasek zębaty
  • koło zębate x2
  • Klucz imbusowy
  • Bracket Kit
Steering Potentiometer User Guide
