Aim OTK Kart Brake Position Magnet Holder
Mount Your System
The Aim Brake Position Magnet Holder is a mounting bracket made specifically for use with the brake position sensor kit, designed for OTK karts.
Why Choose the Aim Brake Position Magnet Holder
The Aim Brake Position Magnet Holder is designed and engineered to hold the brake position sensor and cable securely in place. It is the same bracket as supplied in the non-contact brake position kit, making it ideal for use as a spare or replacement. An OTK sensor bracket is also available to purchase separately.
Please Note: The magnet is not included.
Uchwyt magnetyczny położenia hamulca
