The Most Precise & Easy Way To Get Lap Times
Upgrade your powerboat setup with one of the best lap timers in the industry — the Solo 2 GPS powerboat lap timer. Equipped with an integrated GPS, built-in gyro, user-friendly interface and compatibility with session performance analysis software, the Solo 2 provides precise lap times, delta times and detailed telemetry for amateur and professional sailors alike to optimise their performance and achieve their goals.
Why Choose the Powerboat Solo 2 GPS Lap Timer
The Solo 2 powerboat lap timer includes a high-precision GPS and receives data from GPS and GLONASS satellite constellations. This allows the device to display instant speed, timing splits, live data and predictive lap times on its high-contrast display with an accuracy of two-hundredths of a second to help sailors improve their performance on the water.
The improved GPS technology in the Solo 2 also provides better reliability from the predictive lap timing function so that you can see, in real time, how your current time compares to your best time. The LEDs are also configurable to give a visual indication on whether you are quicker or slower.
Accurate Lap Times
The Solo 2 powerboat lap timer features a 100Hz 6-axis inertial platform to calculate, show and record lap times, sector times, position & boat speed, with a sampling rate of up to 25Hz, and 3D acceleration & gyro.
Predictive Lap Timing
  • Best lap of the day
  • Best lap of the session
  • Previous lap
  • User reference lap
Showcase of the Solo 2 backlight colour options
The Solo 2 has a sharp, high-contrast display which helps sailors easily identify the data displayed on screen, as well as 8 different backlight colours.
The Solo 2 allows you to create a new temporary or permanent track layout too. Even if there is no map already, the device will create one for you.
Extensive Track Database
The Solo 2 powerboat lap timer includes thousands of pre-loaded courses worldwide, the lap timer automatically recognises your position and starts sampling lap times every time you sail past.
Whatever discipline, the Solo 2 allows you to create a new temporary or permanent layout too. Even if there is no track or course already, the device will create one for you.
Solo 2 Suction Cup, Rollcage & U Bolt Mounts
Mounting Options
A variety of Solo 2 mounts provides an easy installation for a wide range of vehicle types.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SKU: SOLO2-K1-PB
Aim Solo 2 GPS lap timer diagram
Solo 2 pinout
  • Solo 2 laptimer front view
    Solo 2
  • Cable icon
    Wall Charger with AC Adapter
  • Solo 2 laptimer lighter socket cable
    Power Cable with Lighter Socket
Solo 2 User Guide
Solo 2 Tech Sheet
Videos
Overview
Załaduj wideo: A walkthrough of the main features and functions of the Aim Solo 2 lap timer.
Walkthrough
Załaduj wideo: An in-depth review of the main features and functions of the Aim Solo 2 lap timer.
Race Studio
Załaduj wideo: In this episode, we explain how to get the most out of your Solo 2 data to maximise your performance using Race Studio.
How do you mount the Aim Solo 2 in your vehicle, and does it come with mounting accessories?
The Aim Solo 2 comes with a universal mounting bracket, with optional accessories such as a suction cup, U bolt, or roll cage bracket. All mounting options provide a stable and vibration-resistant mounting solution, ensuring accurate data collection during your sessions.
How do you customise the display and LED shift lights on the Aim Solo 2?
Customising the display and LED shift lights on the Aim Solo 2 is straightforward. You can adjust settings directly on the device through its user interface. To do this:
  • Navigate to the "Settings" menu using the side buttons.
  • From there, you can choose various display options, such as switching between lap time, predictive lap timing, speed, and other data fields.
  • To customise the LED shift lights, go to the "Shift Light" setting, where you can set specific RPM thresholds for when the LEDs light up, or you can adjust their brightness and colour. These settings help you optimise performance by providing visual cues while driving.
For more detailed customisation, you can also make changes through the Race Studio 3 software, where additional options like screen layouts are available.
How do you add a new track to the Race Studio 3 database?
There are more than 4,000 pre-loaded track maps in the Race Studio 3 database. However, you can add an open or closed circuit in Menu > Type of Racing > Circuit Type, then select the "TRACK" and "CREATE" buttons. Follow the prompts onscreen or take a look at our track creation guide for more information on how to set up open or closed circuits. You can also take a look at how to configure a Solo 2 to help you learn a new track.
Aim Solo 2 DL
Aim Solo 2
  • 4GB Internal Memory
  • Automatic Track Recognition
  • Integrated GPS
  • Ten Configurable RGB LEDs
  • Wi-fi Connectability
  • GLONASS Receiver
  • Direct ECU Data Logging
  • Predictive Lap Timing
  • Choice of Connection
  • Integrated GPS
  • Graphical Display
  • Solo 2 DL
  • Choice of connection Cable
  • Solo 2
  • GPS: 25Hz
  • Memory: 4GB
  • GPS: 25Hz
  • Memory: 4GB
