Aim Solo Roll Bar Mount (V Bracket)
SKU: SOLO-VB
- Normalna cena
£67.00£80.40INC VAT - UK only
- Normalna cena
- Cena sprzedaży
- £67.00
- Cena jednostkowa
- za
Aim Solo, Solo 2, Solo 2 DL Roll Bar Mount (V Bracket)
The Aim Roll Bar mount is suitable to be clamped to a roll bar, railing or tube. Used to secure for Solo GPS lap timer to your vehicle.
Secure mounting for GPS lap timer | Ball & socket for positioning |
Suitable for Solo, Solo 2 & Solo 2 DL | |
Roll Bar Mount for GPS Lap Timer
The Aim Roll Bar Mount (V Bracket) is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.
It is used to securely mount the Solo, Solo 2 and Solo 2 DL GPS Lap Timers to your vehicle. The V bracket adjusts using a ball and socket type system for optimum positioning and simply clamps to a roll bar, railing or tube.
The duel swivel joint makes the viewing angle adjustment quick and easy and the securing clip has a rubber lining to prevent slipping and any vibrations affecting the display.
These are some of the items that can be added to your setup for incrementing performance and data.
- 90mm arm
- Rollbar bracket
- Clamp base with ball
- Locknut
- 4.5cm and 5.5cm tube clamp
- Gasket
- Screws and washers
- 1 Roll Bar Mount Bracket for Solo, Solo 2, Solo 2 DL
The Aim Roll Bar mount is suitable to be clamped to a roll bar, railing or tube. Used to secure for Solo GPS lap timer to your vehicle.Key Features :
The Aim Roll Bar Mount (V Bracket) is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers. It is used to securely mount the Solo, Solo 2 and Solo 2 DL GPS Lap Timers to your vehicle. The V bracket adjusts using a ball and socket type system for optimum positioning and simply clamps to a roll bar, railing or tube. The duel swivel joint makes the viewing angle adjustment quick and easy and the securing clip has a rubber lining to prevent slipping and any vibrations affecting the display.Expand Your System
These are some of the items that can be added to your setup for incrementing performance and data. ![]() |
- 90mm arm
- Rollbar bracket
- Locknut
- Gasket
