Aim TC Yellow Female to 712 3-Pin Thermocouple Patch Lead
Connect Your System
Aim Thermocouple Patch/Extension Leads are used to extend thermocouple patch leads that connect Aim Thermocouple Sensors, such as an EGT (Exhaust Gas Temperature) Sensor or a CHT (Cylinder Head Temperature) Sensor, to an Aim TC Hub or directly to a MyChron Lap Timer.
Why Choose the Aim Thermocouple Patch Lead
The Aim Thermocouple Patch Lead is a long-lasting, high-quality extension lead that is perfectly suited to your motorsport needs. With a female TC yellow connector on one end and a 712 3-pin male connector on the other, you can effectively monitor and change the temperature of the vehicle when you have this lead on to enhance safety on the track.
Przewód krosowy z żółtego żeńskiego TC na męski 712
