OptiMate Charger 6.0A - 14.4V
OptiMate Lithium Battery Charger
The OptiMate charger 6.0A – 14.4V is a premium charger, maintainer, and tester designed specifically for 12.8V/13.2V lithium iron phosphate (LiFePO₄) batteries. Whether you own a motorcycle, car, boat, or powersport vehicle, this intelligent charger ensures your lithium battery stays healthy, fully charged, and ready to perform.
Built with advanced microprocessor technology, the OptiMate battery charger doesn’t just charge – it diagnoses, recovers, balances, and maintains your battery with precision. Its automatic multi-step program adapts to the condition of your battery, making it one of the safest and most efficient lithium battery chargers available.
Why Choose the OptiMate Charger 6.0A – 14.4V
When you invest in a lithium battery, you want it to deliver maximum performance for as long as possible. The OptiMate charger 6.0A – 14.4V is engineered to do exactly that. Its intelligent microprocessor not only charges quickly and efficiently but also actively balances the cells inside your LiFePO₄ battery, unlocking more consistent power and extending overall lifespan.
Unlike standard chargers, the OptiMate charger goes beyond simple top-ups. It diagnoses, recovers, and maintains your battery, protecting it against common issues such as overcharging, deep discharge, and cell imbalance. That means less downtime, fewer costly replacements, and the confidence that your vehicle will start reliably, even after long periods of storage.
Ease of use is another major advantage. With fully automatic operation, you simply connect the charger and let it handle the rest. The OptiMate charger 6.0A – 14.4V adapts to the battery’s needs in real time, selecting the right program to ensure safe and efficient charging every time. Whether it’s for a motorcycle, ATV, car, or boat, this charger is versatile enough to handle them all, making it a professional-grade solution trusted by enthusiasts worldwide.
Ładowarka OptiMate 6A z wybraną wtyczką
Videos
Optimate 6.0A Charger Overview
