This MyChron 6 is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
The Aim MyChron 6 is our GPS lap timer specifically crafted for karting. Combining 30 years of experience with advanced technology, the MyChron 6 offers precise lap timing and advanced data analysis for both amateur and professional racers.
The MyChron 6 GPS Karting Lap Timer fitted to a red Aim Kart
Why Choose the MyChron 6 GPS Lap Timer 
The MyChron 6 GPS lap timer revolutionises how drivers and teams monitor and analyse performance on track. Due to its highly accurate 25Hz GPS tracking, large screen displaying delta times and comprehensive data logging capabilities, the MyChron 6 lap timer provides detailed performance analysis from split times and overall delta time, racing lines, cornering speeds and braking points.
Please Note: The MyChron 6 is compatible with the most common heart rate monitors on the market.
Załaduj wideo: The advanced display features, and backlight colours, of the MyChron 6
Advanced Display
The MyChron 6 features a wide graphical display, ensuring excellent readability. Brightness and contrast are automatically adjusted to maintain ideal visibility in all lighting conditions, and this allows drivers to clearly monitor not only their best vs current sector times, but also their heart rate, delta, delta bar graphs and more, allowing real time adjustments to be made, improving lap performance.
Załaduj wideo: Delta times LED display feedback on the MyChron 6 Lap Timer
Delta & Predictive LED Icons
MyChron 6 on-screen Delta bar
On-Screen Delta Bar
An exclusive on-screen delta bar animation showcases instant graphical feedback on your live performance, showing how your current timing compares to your best.
Showcase of the MyChron 6 backlight colour options
The MyChron 6 has a sharp, high-contrast display which helps drivers easily identify the data displayed on screen, as well as 8 different backlight colours.
Załaduj wideo: LED & Alarms System on the MyChron 6
LED & Alarms System
Załaduj wideo: Integrated shift light array interface and customisable alarms for the MyChron 6
Cylinder Head Temperature Sensors, Exhaust Gas Temperature Sensors, and Water Temperature Sensors
Available Sensors
The MyChron 6 GPS lap timer uses a range of sensors to monitor engine performance and prevent damage. Choose from:
  • Cylinder Head Temperature (CHT) Sensor: Tracks the engine’s combustion temperature, helping avoid overheating, especially when tuning.
  • Exhaust Gas Temperature (EGT) Sensors: M5 and T12 EGT sensors measure exhaust temperatures to fine-tune the air/fuel mix, vital for performance and engine safety.
  • Water Temperature Sensors: Available in M10 (for Rotax, X30, OK) and M5 thread sizes, these sensors monitor coolant temperature to ensure the engine runs within its optimal range, with size options to suit different engines or fittings.
Aim MyChron 6 analysis on Race Studio 3
Race Studio 3 Analysis
Your data can be downloaded via cable, Wi-Fi or Mini USB storage, and analysed in depth using Race Studio 3 software, available to download on desktop or our mobile app: charts, graphs and histograms will help you to understand your performance, finding out what needs to be improved.
You can compare the data that cannot be shown on displays, with a lot of dedicated views like track split report, channel report, SmartyCam videos and so on, also comparing different sessions.
Aim MyChron 6 Expansions; ACC3, Data Hub, SmartyCam 3, Tyre Temperature Kit, LCU-One S and more.
Upgrade your MyChron 6 lap timer with sensors and expansions for complete data control; OTK non-contact brake, throttle, and brake pressure kits track pedal travel and force, while wheel speed, water temp, CHT, EGT, and steering angle sensors deliver precise performance metrics.
The Data Hub multiplies CAN connections, with powered and non-powered options, with power coming from the 20-hour MyChron Lithium Battery, or a direct 12V external lead.
  • Display: Graphical
  • Backlight: 8 configurable RGB LEDs
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • Bluetooth Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • CAN Connections: 2
  • Connectors: 1 connector (binder) 712 fem 3 pins, 1 connector (binder) 712 fem 5 pins & 1 connector (binder) 712 fem 8 pins
  • USB Connections: For data download, mass storage support and battery charging
  • Temperature Input: 1
  • Digital Inputs: Optical lap signal, magnetic lap signal
  • External Modules: MyChron Expansions, IR Temperature Controller, SmartyCam 3 Series, Lambda (LCU-One and LCU1S)
  • Memory: 4GB
  • Battery Life: 20h approx.
  • Body: PA6 GS30%
  • Dimensions: 150.0 x 79.0 x 36.6mm
  • Weight: 370g
  • IP67
SKU: 35020126
MyChron 6 User Guide
MyChron 6 Tech Sheet
What are the key features of the Aim MyChron 6?
The Aim MyChron 6 GPS Lap Timer is a high-performance piece of karting equipment that offers extremely advanced data logging capabilities. Along with heart rate, braking points, racing lines and more, it ensures that every second you're racing is monitored and recorded.
The MyChron 6 Lap Timer has delta times shown, letting you compare your current lap with others to see exactly where you are gaining or losing seconds in real time. The GPS module is also extremely accurate to 25Hz, allowing for advanced tracking capabilities and data collection.
Ultimately, lap timing and data collection are upgraded massively with the MyChron 6 Lap Timer, with multiple karting parameters being monitored and recorded for performance analysis.
How does the MyChron 6 Lap Timer work?
The Aim MyChron 6 GPS Lap Timer relies on satellite positioning, electromagnetic induction and thermal sensors to convert track data into readable information. Before you even start driving, the MyChron 6 connects to satellites and recognises the track using the automatic track recognition technology.
What software can the MyChron 6 Lap Timer use?
The MyChron 6 can be used with our free Race Studio 3 software for comprehensive data analysis and data management post-session to identify areas of improvement to remain competitive. Race Studio also allows you to configure and customise LED light arrays, sensor inputs, update firmware and more.
Does the MyChron 6 Lap Timer work with other Aim products?
What are the differences between the MyChron 6 and the MyChron 6 2T?
How does the MyChron 6 compare to the MyChron 5?
