The Best Motorsport Bullet Camera & More
The Aim SmartyCam 3 GP Pro camera system uses a robust and compact bullet camera making it perfect for single seaters, motorcycles, and other applications where cockpit space is limited.
The camera is available in three lens versions, each with a choice of a bullet camera length of 1m, 2m, 3m, 4m or a custom cable length and a 2m or 4m CAN expansion cable, making it one of the best motorsport bullet cameras in the industry, with even more advanced features.
Please Note:  The camera MUST be externally powered as the internal battery is only designed for initial configuration, and returns are not accepted for custom cable lengths.
Załaduj wideo: SmartyCam footage in motorsport setup
Why Choose the Aim SmartyCam 3 GP Pro
The SmartyCam 3 GP Pro is purpose-built for harsh motorsport environments, eliminating the seasick “wave effect” of standard cameras with its global shutter CMOS sensor that handles engine vibrations at high RPM. Whilst staying true to the unmatched features of the standard SmartyCam 3 GP, the SmartyCam 3 GP Pro features a 64GB internal EMMC storage that operates on a loop recording basis, overwriting the oldest files when full. Its two AS Micro Xtra Lite Deutsch connectors also offer enhanced durability and reliability in professional racing environments.
The Aim SmartyCam 3 GP Pro features a coaxial bullet cable with enhanced electromagnetic noise protection, an integrated CAN bus hub with dedicated ports for bullet cam, video output, GPS, and expansion, plus an optional CAN ECU connection for direct access to ECU data via Aim protocols. Designed in machined aluminium and sealed to high waterproof standards, the GP Pro withstands extreme weather and vibrations, while sound recording can be improved with an external mic. Paired with free Race Studio 3 software, drivers and teams can easily split and compare laps for detailed video analysis and performance review.
SmartyCam 3 GP can automatically recognise which track you're on and begin mapping - if your track does not register, you can create your own custom track within Race Studio 3.
With Race Studio 3 software you can also configure your overlay. Add your logo and track map; choose your graphic elements from a list of pre-determined sets with the same layout or even single objects from different sets, and your videos will be truly yours.
Załaduj wideo: Showcase of the RS3 Software on laptop devices
Video Output/Streaming
SmartyCam 3 GP Pro features a video output with SD interface. It allows you to send the video/audio directly to wherever you choose, for example your pit crew, at 30 or 60fps.
All The Data You Need
From speed, RPM, and lap number, to gear shifts and much more, data can be read from all possible sources. From GPS; track map and vehicle position as well as speed, lap and split times, or from an Aim logger; RPM, throttle, engaged gear, acceleration, temperatures, pressures can be recorded as well.
Containing a full internal datalogger, all data received from the CAN bus and from the internal sensors are recorded in .mp4 files produced at the end of your test, your SD (or MSD) Card contains all the information you need for a deep data analysis.
Higher Storage Capacity
Other HD cameras often chase higher pixel counts which leads to huge file sizes without much real benefit. The SmartyCam 3 GP Pro is different: it uses smart H.264 compression settings that keep the video quality you need while keeping file sizes small. This means you can quickly download and review footage at the track for data analysis, instead of dealing with huge cinematic files that look pretty but slow you down.
Choose between three file quality levels: One hour recording = 4GB (high quality), 2GB (normal quality) or 1.5GB (lower quality).
The SD card housing on the Aim SmartyCam 3 GP Pro is 100% protected from air and weathering.
SD cards sold separately.
Expand your SmartyCam 3 GP with an MXS display, ACC3, Data Hub and sensors
Overlay your delta, predictive, timing splits, lap data and more in Race Studio 3 when you pair the SmartyCam 3 GP with the Aim Solo 2 DL GPS lap timer. Expand your system further with additional sensors and expansions such as the ACC, LCU-One S, Data Hubs, sensors and more. Please see the connections tab for connection examples.
  • Display Resolution: 2.4” 240 x 320 pixels
  • CMOS Sensor: Global shutter
  • Field Of View: 67°, 84° or 120°
  • Video Out: 3G-SDI
  • External Power: 9-15V
  • Connectors: 1 7-pin binder 712 female, 1 5-pin 712 binder + 2 SMA female connectors (see pinout page) & 1 USB-C
  • Auto Power ON/OFF: Yes
  • Body: Anodised aluminium
  • Bullet Cable Length: From 0.5m to 4m (7 lengths available)
Dimensions:
Weight:
  • Main Unit: 320g
  • Bullet Camera: 45g
Microphone Connectors On SmartyCam
SmartyCam 3 GP pinout
  • SmartyCam 3 GP Pro front view
    SmartyCam 3 GP Pro
  • USB cable icon
    USB-C Cable
  • Cable icon
    Your Chosen Connection Cable
  • SmartyCam 3 bullet camera
    Bullet Camera
  • Cable icon
    Coax Cable
  • AiM Solo 2 and Solo 2 DL mains charger with UK plug power cable for lap timer accessories
    12V Mains Charger
  • Cable icon
    2x Autosport Connectors
SmartyCam 3 GP User Guide
SmartyCam 3 GP Tech Sheet
