Mount Your System
The Yamaha Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for Aim Solo 2 and Solo 2 DL Lap Timers. The bracket is compatible with Yamaha YZF-R1 (YEC incl.) motorcycles from 2004-2014 and YZF-R6 (YEC incl.) motorcycles from 2004-2016.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket ensures your Solo 2 GPS Lap Timer can be securely mounted on your Yamaha motorcycle. Supplied with all the necessary hardware, it provides a quick and stress-free installation, so you can accurately track and monitor your laps with ease.
Yamaha YZF R1M Motorcycle
Plug & Play Cable
Separately sold plug & play cables are also available for the following Yamaha motorcycle models and years:
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
  • For Yamaha motorcycles only
  • Compatible with YZF-R1 (YEC incl.) 2004-2014 and YZF-R6 (YEC incl.) 2004-2016
  • Mounting bracket for the Solo 2 & Solo 2 DL Lap Timers
SKU: YAM-2-B
Part Number: X46KSYR16
  • Uchwyt Yamaha Solo 2/2 DL
  • przekładki x2
  • x2 nakrętki samozabezpieczające M6
  • x4 podkładki M6
  • x2 nakrętki samozabezpieczające M4
  • x2 podkładki M4
  • śruby imbusowe z łbem płaskim x2 M4x10mm
  • śruby imbusowe x2 z łbem okrągłym M6x60mm
Yamaha User Guide
