Boost Pressure Sensor 1/8 NPT 0–50 PSI
The Aim Boost Pressure Sensor is suitable for brake, oil, fuel and water pressure readings, reading pressures up to 50 PSI. This pressure sensor measures exactly how much pressure passes through.
When dealing with an Absolute Pressure Sensor, or a Manifold Absolute Pressure (MAP) sensor, there is one key difference: it measures pressure relative to a perfect vacuum, not relative to the air around us. This means that even when the engine is off, the sensor will still show a reading (atmospheric pressure).
Why Choose the Aim Boost Pressure Sensor
The Absolute Boost Pressure Sensor 0–50 PSI is available in 1/8 NPT thread options and is fitted with a 4-pin 719 male binder connector to suit Aim loggers, dash loggers, lap timers and dash displays. Many aspects affect various engine pressures, so knowing your engine has the correct amount of pressure is paramount to longevity and performance.
Using Absolute Boost Pressure Sensors is the gold standard because it allows the engine to perform consistently regardless of location; whether you are racing at sea level or high up in the mountains.
If there is a pressure change, incorporating an Absolute Pressure Sensor into your setup will allow it to be detected and signalled to prevent the worst. You can see through live telemetry about what’s happening as the sensor turns the physical force of fluid pressure into a predictable electrical signal that can be monitored to protect your engine.
How the Boost Pressure Sensor Works
The Aim Absolute Pressure Sensor is installed directly into the air intake or boost line. Inside the sensor is a sensitive internal component, typically a thin diaphragm with a vacuum sealed behind it.
As the turbocharger or supercharger generates boost, that air pressure forces the diaphragm to flex. The sensor precisely measures this movement and converts it into an electrical voltage signal:
  • Minimum Pressure (0 PSI Absolute): The sensor outputs its lowest voltage, typically 0.5 Volts (V). This represents a total vacuum.
  • Maximum Pressure (50 PSI Absolute): The sensor outputs its peak voltage, typically 4.5 Volts (V).
This is a linear scale, meaning the voltage increases at the same rate as the pressure. For example, if the pressure is exactly halfway (25 PSI Absolute), the voltage will also be halfway (around 2.5V).
Absolute boost pressure sensor is available in PSI or Bar variants
0-50 PSI Absolute Pressure Sensor
The pressure sensor allows you to detect fluid and air pressures. It offers a high level of reliability and endurance and is protected against the high vibration, shock and high temperatures found in motorsport.
The Aim boost pressure sensor is available with terminated and unterminated connectors for compatibility with external manufacturers
We also offer unterminated sensor that are designed to work seamlessly with Bosch, MoTeC, Cosworth, or other manufacturer hardware, making it easy for you to integrate the reliable and efficient Aim Pressure Sensors into any setup.
The Aim boost pressure sensor is expandable with ACC3, Aim displays and display loggers, XLog, Data Hub and more
You can expand your system with a range of products from the ACC3 Analogue CAN Converter, Displays and Loggers, Data Hubs and more.
  • Supply: 8-16V
  • Characterisation: Start of scale 500 mV, End of scale 4500 mV
  • Consumption: < 10 mA
  • Burst Pressure: 3 x rated pressure
  • Temperature Working Range: -20°C to 135°C
  • Waterproof Rating: IP67
  • Housing: 316 stainless steel
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: 1/8 NPT
SKU: S-P-NPT-A-50
Part Number: X05PSA00050P18AK
Oil/Fuel Pressure Sensor 010 Bar Diagram
Pressure sensor pinout
Pressure Sensor Tech Sheet
