AiM SmartyCam HD Track Day Camera
The AiM SmartyCam HD Rev 2.1, Motorsport Video Logger Camera, is ideal for car interior installation where a narrower field of vision (FOV) is needed.
Key Features:
Real Time OverlaySmartyCam HD automatically overlays on your video all of the data you need: speed, RPM, lap number, gear shifts and much more. Simply choose the data and graphical layout you prefer from the many different overlays available. Data can be read from all the possible sources. From GPS: track map and vehicle position as well as speed, lap and split times. From AIM logger / dash logger connected to your ECU: RPM, throttle, engaged gear, acceleration, temperatures, pressures etc. From additional sensors connected to your AIM logger / dash logger. |
CMOS Sensor & LensesBeing a camera dedicated to motorsports. The SmartyCam HD features lenses specifically designed to avoid distortion. The camera is available in three versions: The 67° lens is preferred for closed-roof cars, as it "sees" the track just within the wind-screen pillars, reducing that unpleasant black frame typical of generic camera on-board videos. A 84º lens is available for open-roof and formula cars, where it is possible to have a more ample view of the track and there is no risk of black frames. For an even wider view of the track a 120º lens option has been added to the range. |
Designed for extreme conditions
Higher Storage Capacity
SmartyCam Connections |
- Video Format: H.264 1280 X 720 pixels @ 30 fps
- Display Resolution: 128 X 128 pixels
- Lens: Telecentric with 6 elements
- Field of View: 67°, 84°
- Internal Battery: Rechargeable Lithium Battery - 1,950mAh
- Battery Charge: 700 mAh 12V
- Internal Battery Duration: 120 - 150 of recording
- External Power: 9 - 15 V
- Supported SD Card: Up to 128 GB
- Memory Capability: 1.5 GB ( 1 hour low quality recording)
- 2 GB ( 1 hour medium quality recording)
- 4 GB. ( 1 hour high quality recording)
- Accelerometer: Three-axial + 5G
- Usage Temperatures: _10°C / +60°C
- Auto Power ON: Yes if connected to the AiM logger
- Auto Power OFF: Yes
- Body: Anodized Aluminium
- Dimensions: 87 x 63 x 49mm
- Bullet Cable Length: 2.0m
- Weight: 280g battery included
- SmartyCam HD Rev 2.1
- Dash or Logger Connection Cable, 2m or 4m (as selected)
- Battery charger
- USB/AC power adaptor
- Software Installation CD
