Aim GPS09 Module Pro Open
SKU: GPS-O-P...
£420.00£504.00INC VAT - UK only
- £420.00
Please note - OPEN devices must be programmed in Race Studio 3 via USB to enable them to transmit data on none preset CAN ID's
The coveted Aim GPS, now available to everyone.
GPS09c Open is a stand-alone device that can stream, in completely configurable messages, all the GPS data at 25Hz. It is proposed also in the Pro version that features also a 100Hz 6 axis IMU.
GPS channels available at 25Hz:
- Altitude
- Latitude
- Longitude
- Sats number
- Pos Accuracy
- Speed Accuracy
- GPS Lateral acceleration
- GPS Linear acceleration
- GPS Heading
- GPS Yaw Rate
- GPS Hour
- GPS min
- GPS Sec
- GPS Millisec
- Year
- Month
- Day
- Week number
- iTOW
- Unix Time
IMU data available through CAN connection at 100Hz (GPS09c Pro Open only):
- Acceleration X
- Acceleration Y
- Acceleration Z
- Pirch rate
- Yaw rate
- Roll rate
GPS09c Open is developed to be compatible with all Aim or not Aim systems.
It offers three output streams; for not Aim systems you can configure the protocol for a CAN or RS232.
OPEN RS232
Freely user configurable
OPEN CAN
AIM CAN
To be connected as expansion
using the Aim CAN network
CAN connection
Aim Race Studio 3 software offers the possibility to freely configure the CAN messages.
It is possible to set:
- Baud rate
- ID
- DLC (1-8 bytes)
- Byte order
(little endian, big endian) - Messages frequency
RS232 Connection
GPS09c Open may be configured for transmitting the GPS NMEA message you need through an RS232 stream.
- Baud rate
- ID
- DLC (1-8 bytes)
- Byte order
Both GPS09c Open and GPS09c Pro Open are proposed in two different mechanical versions. Vehicles with a carbon fibre roof or reduced glass surface may limit the GPS signal: the Roof version of Aim GPS09c Open is specifically designed to avoid signal loss.
Aim GPS09 Module
- Weight: 60.5g
Aim GPS09 Module
- GPS09 Module
- Altitude
- Latitude
- Longitude
- Sats number
- Pos Accuracy
- Speed Accuracy
- GPS Heading
- GPS Yaw Rate
- GPS Hour
- GPS min
- GPS Sec
- GPS Millisec
- Year
- Month
- Day
- Week number
- iTOW
- Unix Time
- Acceleration X
- Acceleration Y
- Acceleration Z
- Pirch rate
- Yaw rate
- Roll rate
OPEN RS232
OPEN CAN
AIM CAN
CAN connection
Aim Race Studio 3 software offers the possibility to freely configure the CAN messages.- Baud rate
- ID
- DLC (1-8 bytes)
- Byte order
RS232 Connection
GPS09c Open may be configured for transmitting the GPS NMEA message you need through an RS232 stream.- Baud rate
- ID
- DLC (1-8 bytes)
- Byte order
Aim GPS09 Module
- Weight: 60.5g
Aim GPS09 Module
- GPS09 Module
