    Kart Brake Pressure T-Piece - AimShop.com
    AiM Kart Brake Pressure T-Piece - AimShop.com
    S-TP-OTK
    £70.00
    £70.00
    The stainless steel brake pressure sensor T Piece is suitable for all OTK karts. The T-Piece is mounted in the brake line to facilitate adding a brake pressure sensor, providing valuable analysis data for the driver to review.
    Suitable for all OTK karts Made from stainless steel
    Suitable for M10 sensor
    No adaptors are needed, your original brake line will screw onto the end of the T piece once fitted
    Very strong and designed to withstand the rigours of karting
    Suitable for an M10 x 1.0 sensor
    • Brake Pressure T-Piece
    • Stainless Steel
    • Suitable for OTK Karts
    • Compatible with MyChron4 and MyChron5
    • Suitable for M10 Sensor
    • 1 x Brake Pressure T-Piece
