    Aim Mychron5 S 2T Patch Lead Double Yellow TC Plugs - AimShop.com
    P-712-TC-TC
    Aim MyChron 2T Patch Lead Double Yellow TC Plugs
    Hurry, only 9 items left in stock!
    £50.00
    £50.00
    AiM Mychron5 S 2T Patch Lead Double Yellow TC Plugs
    The AiM MyChron5 s 2T (2 Temperature) model MyChron4 and MyChron5. These patch leads are used for connecting different temperature sensors to the dash.
    Double Yellow TC plugs Suitable for fitting EGT, Underplug sensor
    Compatible with MyChron 4 & 5
    Connects to the three-pin (712) TEMP port on the Mychron dash.
    This AiM Double TC Mignon Plug is suitable for fitting an Exhaust Gas Temperature Sensor (EGT) and an Underplug Temperature Sensor or 2 x Exhaust Gas Temperature (EGT) or 2 x Underplug Temperature Sensors.
    Cable length 1.5m
    • MyChron5 S 2T patch lead with double TC plugs
    • Add two water temperature sensors with this patch lead
    • Cable length: 1.5m
    • MyChron5 S 2T Patch Lead Yellow TC Plugs
