    Aim SmartyCam Replacement Lens Ring - AimShop.com
    SM-EC
    £20.00
    £20.00
    The Aim replacement lens ring is for the SmartyCam HD & Corsa camera.
    Fits SmartyCam HD & Corsa Ideal replacement or spare
    Steel lens ring
    Aim SmartyCam Replacement Kit
    The Aim replacement lens ring is for the SmartyCam HD & Corsa camera. It is needed as a replacement should the lens ring become damaged or spare to keep with your camera kit.
    Steel lens ring
    For the SmartyCam HD & Corsa
    • Replacement Lens Ring - For SmartyCam HD & Corsa
    • Aim SmartyCam Replacement Lens Ring
