Aim Solo 2 DL Motocross Track Day Lap Timer Kit
Choose Accessories
Upgrade your motocross setup with one of the best motocross lap timers in the industry — the Solo 2 DL Track Day Kit. Now available as a plug & play unit, display instant speed, timing splits, live data and predictive lap times on a high-contrast display with an accuracy of up to two-hundredths of a second, all specific to your bike model, just plug it in and go! See your exact riding line, compare it to optimal lines for faster lap times, track your bike’s movements and provide detailed data on acceleration, braking, and cornering forces. Do all of this and more with direct ECU data logging for instant, trackside, or post-race analysis with all your logged performance data.
Why Choose the MX Solo 2 DL Track Day Lap Timer Kit
Building on the features of the Aim Solo 2 model, the Solo 2 DL MX lap timer connects directly to your bike’s ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and bike ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
Plug & Play Compatibility
The kit comes with a cable to connect the Solo 2 DL to your bike, relaying all vital ECU information. The cable is specific to your bike model.
Plug & play is currently available for the following bike models:
- TM Racing
- GET GP1 & GET Power
- Suzuki
- Microtec M222
- Microtec M206
- Honda
Please select your model before adding the Solo 2 DL Plug & Play Kit to your cart.
The Solo 2 DL motocross lap timer has a sharp, high-contrast display which helps riders easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide track maps are available, the bike lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to ride, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you ride past.
The Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Inertial Platform
- Create, modify and manage configurations for a customised display
- Perform in-depth data analysis to compare lap times, sector performance and more
- Overlay data performance data onto your SmartyCam video footage for post-race review
- Access the extensive track database within Race Studio 3 to ensure accurate lap timing and data logging
- Save new track layouts directly from Race Studio for future sessions
To take your data one step further, the Aim Solo 2 DL seamlessly connects to Aim SmartyCams and a variety of MX sensors to increase your data performance and enhance your analysis with the added visuals and overlays, as well as additional sensor information.
Pinouts
Solo 2 DL
Power Cable with AC Adapter
Your Chosen Connection Cable
Videos
Overview
Configuring
- How can I configure SmartyCam HD/GP HD with Solo 2 DL?
- How can I transmit more than a configuration to my Solo 2 DL and how can I choose which one to enable?
- In which way can I display gear information on my Solo 2 DL?
- My Solo 2 DL turns on automatically, when left plugged into the OBDII port: what can I do?
Track Functions
| Specs |
Aim Solo 2 DL
Aim Solo 2
