G5 Voodoo Neo 4
G5 Voodoo Neo 4
G5 Voodoo Neo 4
The next generation of engine management for many more engines.
The G5 Voodoo Neo 4 Can Run:
- 6 cylinders port or direct injection and direct spark, or,
- 4 cylinders with direct/port staged injection, and direct spark
The G5 Voodoo processing units are the perfect choice for professional level motorsport.
G5 Voodoo Neo Key Features
- An all-new communications module: 10x faster USB speeds (from minutes down to seconds to download log files), Ethernet, and enhanced WiFi and GPS.
- 1GB of onboard logging memory, double that of other Link ECUs.
- Highly customisable IO, using 2 types of multi-purpose pins - Injection/Ignition/Aux pins and dual-purpose ADIO pins.
- Dual onboard E-throttle, with H-bridges that now natively support things like modern e-wastegates or e-blow off valves.
- 1 onboard wideband.
- Configurable analogue temp inputs, with 2 different pull-up resistor values (1kΩ and 10 kΩ), allowing more types of sensors to be used.
- Analogue temp pull-ups can be disabled now, allowing analogue temps to be used as regular analogue volt inputs.
- K-line support.
- CNC case, sealed enclosure.
Huge Time & Flexibility Gains For Installers
- You can now power via the USB cable, just like the Razor PDM, making setting up the initial tune a breeze at your PC.
- More mounting options than ever before, with through holes, and threaded mount holes on the side and underneath.
- New WEIPU CAN connector supplies power for CAN devices, massively simplifying CAN wiring and accessory installation.
- Highly customisable IO, with multi-use pins to maximise utilisation.
- Similar pinouts to G4X, allowing upgrades with minimal repinning.
Neo 4
Videos
Introducing The G5 Voodoo Neo
