    Link B Loom Long #5LB cable loom by Link
    Link B Loom Long #5LB cable loom and wiring harness component draped on a white background
    Link B Loom Long #5LB cable loom by Link for organized wire harness protection
    5LB
    Link "B" Loom Long - #5LB
    £195.00
    £195.00
    5 m long 'B' loom to suit G4, G4+ and G4X ECUs
    Perfect for all custom wiring jobs utilising Link WireIn ECUs. The ‘B’ Loom has a Link ‘B’ ECU connector at one end and unterminated wires at the other. All wires are colour coded to match the manual. This loom is also available in 0.4m and 2.5m lengths.
    Added features of 2.5m and 5m ‘B’ Looms include:
    -Shielded Dual-Core wires for knock signals
    Suitable Applications:
    Link G4X Storm (Loom A also required)
    Link G4X and G4+ Fury (Loom A also required)
    Link G4X, G4+ and G4 Xtreme (Loom A also required)
    Link G4+ Thunder (Note: Loom A and connector kits C and D may also be required)
    Link G4+ Storm Black (Loom A also required) – Note: Loom B is not required for the older Silver or Blue G4 or G4+ Storm models
    Vipec V88 (Loom A also required)
    Vipec i88 (Loom A also required)
    • "B" Loom Long 5m
