    Super B Andrena 12V25Ah Lithium Battery - AimShop.com
    SB-25
    In stock, ready to ship
    Choose Accessories
    £1,025.00
    £1,025.00
    Light-weight, high-performance, safe and reliable lithium power battery, especially developed for motorsports. This battery equals a lead-acid battery of 100 to 130Ah, provided the alternator’s maximum current doesn’t exceed the battery’s maximum charge current of 77A. Designed in a standard rally casing. Suitable for 12V systems and for use in extreme environments.
    Lightweight Power
    With a weight of only 4.3kg /9.5lbs, the Andrena 12V25Ah power battery saves up to 80% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This improves not only the performance of your vehicle but also helps to increase the fuel economy.
    The power battery offers a high level of power, fast charging and a long, maintenance-free service life. It also has a stable and flat discharge which means you have over 80% of the batteries capacity available and you can leave your vehicle unattended for a much longer period compared to a lead-acid battery.
    Safe & Reliable
    Super B batteries are based on lithium iron phosphate technology (LiFePO4). This is the safest lithium  technology available today. On top of that our bespoke casing and electronics further increase safety  and durability. Due to its high ingress protection class (IP69) the battery is completely dust tight and  waterproof . Therefore the battery can be used in the most extreme environment as well.
    Performance
    Fast charging
    Lightweight
    Compact size
    Low self-discharge
    High discharge rates
    3 Year Warranty
    ELECTRICAL SPECIFICATIONS
    Nominal Capacity 25Ah
    Energy 320Wh
    Nominal Voltage 12.8V
    Open Circuit Voltage 13.2V
    Self Discharge <3% per month
    EqPb (Equals lead-acid)  100 to 130Ah
    MECHANICAL SPECIFICATIONS
    Dimensions (LxWxH) 249 x 96 x 141mm | 9.80” x 3.78” x 5.55”
    Weight 4.3 kg / 9.5lbs
    Case Material PC - ABS
    Ingress Protection IP69
    Charge Method CCCV
    Charge Voltage 14.3V - 14.6V
    Max Charge Current 77A
    End of Discharge Voltage 8V
    Discharge Current Continuous 385A
    Discharge Pulse Current (1 sec) 1045A (42C)
    TEMPERATURE SPECIFICATIONS
    COMPLIANCE SPECIFICATIONS
    EAN-13 8718531360082
    Battery Designation 4IFpR27/66-10
    Data Sheet
    Technical sheet
    Guide
    Quick Start Guide
    User Manual
    User Manual
