    Yamaha Plug & Play Aim Taipan Y Motocross ECU Kit - AimShop.com
    C-ECU-YAM-250F-19
    Choose Accessories
    £635.00
    Spark Software Download Icon
    £635.00
    AiM Taipan Y ECU Plug & Play Kit For Yamaha Motocross Bikes
    Taipan Y is the brand-new aftermarket plug & play ECU created by AiM, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
    Taipan Y Key Features & Advanced Strategies
    Traction Control
    Traction Control Strategy
    Launch Control
    High Technology 32-bit Core
    Engine control requires precision. At 20,000 RPM the Taipan Y ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 usec for turning the spark ON!
    Advanced Base Maps For Your Yamaha
    Aim Taipan Y ECU includes a base map that immediately offers improved performance over the OEM control units.
    Taipan Y ECU currently fits the following Yamaha motocross bikes :
    UC Bridge
    User License : A Taipan Y ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
    - Receiving diagnostic information from the Taipan Y ECU.
    Tuner License :
    Taipan Y ECU Connections
    The Taipan Y ECU has 4 connectors :
    Aim Handlebar Switch
    Below shows a functional diagram of products that can be added to the Taipan Y ECU:
    AiM Taipan Y ECU Plug & Play Kit for Yamaha
    • One low side driver (1 A)
    • Power consumption 150 mA
    • n. 1 33 pin male Connector
    • Body: PA6 + 30% glass fiber
    • Waterproof: IP67
    • Weight: 260g
    • Plug & Play ECU for Yamaha
    • UC Bridge
    • Handlebar Switch
    User Guide Tuning Manual Technical sheet Race Studio 3 Spark Tuning Software
