The Ultimate Track Day Kit
The Aim SmartyCam 3 Sport & Solo 2 DL with double bracket is a must-have kit for competitive testing and track days. It combines the Solo 2 DL data logging lap timer with the SmartyCam 3 Sport onboard motorsport camera, allowing you to easily review parameters such as speed, engine revs and cornering G-force against track position to see where lap times can be improved.
Ladda video: SmartyCam Sport video footage showing Solo 2 DL in a motorsport setup
Accurate Lap Timing, Real Time & Post-Session Review
The Solo 2 DL lap timer provides key information: lap times, lap count, delta times and predictive lap times. With over 4,000 tracks already loaded onto the database from across the globe, you can automatically select your nearest track based on your current position.
Log your vehicle’s ECU data for reviewing after a race day to help improve driver performance or vehicle set-up, and capture every lap in full HD and overlay lap and ECU data onto the footage for the ultimate lap-by-lap review.
On-Screen Delta Feedback
Ladda video: Showcase of the SmartyCam 3 Sport features
Paired With The Best Onboard Motorsport Camera
The Aim SmartyCam 3 Sport is an incredibly compact and robust video camera, which has been designed to provide great videos of your racing and include all the technical information you need to help improve your performance on race and track days. 
With the SmartyCam 3 Sport, you can record your entire session in glorious high definition. A high-quality CMOS sensor also provides outstanding video quality and stability for later review. The SmartyCam 3 Sport automatically overlays on your video all the data you need, including speed, RPM, lap number, gear shifts and much more. You can choose the graphical layout to suit your requirements from the various overlay options available.
Inertial Platform
The Solo 2 DL calculates, displays, and records lap times, sector times, position & vehicle speed, with a sampling rate of up to 25Hz, and 3D acceleration & gyro. This allows you to see your exact racing line, compare it to optimal lines for faster lap times, track your vehicle’s movements and provide detailed data on acceleration, braking and cornering forces.
The Solo 2 has a sharp, high-contrast display which helps sailors easily identify the data displayed on screen, as well as 8 different backlight colours.
The Solo 2 allows you to create a new temporary or permanent track layout too. Even if there is no map already, the device will create one for you.
Solo 2 lap timing features
Predictive Lap Timing
  • Best lap of the day
  • Best lap of the session
  • Previous lap
  • User reference lap
Ladda video: SmartyCam Sport & Solo 2 DL data being analysed on Race Studio 3
Both the data recorded from the Solo 2 DL and the video from the SmartyCam 3 Sport can also be combined in our free analysis software, Race Studio 3. This allows you to review your driving and compare data such as speed, G-forces, throttle position and more, and acts as a performance tool to assist you in improving your driving skills by providing a visual reference for driving lines and technique.
A Compact Mounting Solution
Providing a compact and neat mounting solution, both the Solo 2 DL and SmartyCam 3 Sport can be secured in place on the included double bracket mounting frame. The kit can be mounted in the vehicle via a powerful suction cup for use on the windscreen or dashboard, or by securely fastening to a roll cage. This provides various options depending on circuit or driver requirements for a quick and easy transfer from vehicle to vehicle.
Solo 2 DL
  • Display: Graphical LCD
  • Integrated Track Database: Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SmartyCam Sport
  • CMOS Sensor: Global shutter
  • Field Of View: 67° or 84°
  • Auto Power ON/OFF: Yes
SKU: SM-SOLO2
Pinouts
  • Solo 2 DL
  • Cable icon
    Your Chosen Connection Cable
    12V Mains Charger
  • SmartyCam 3 Sport
  • CAN Connection Cable
  • AiM Solo & Solo 2 & Solo 2 DL Suction Cup Mount - AimShop.com
    Suction Cup Mount
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
SmartyCam 3 Sport User Guide
SmartyCam 3 Sport Tech Sheet
Videos
Overview
Ladda video: An in-depth review of the main features and functions of the Aim Solo 2 DL track day lap timer.
