Get Advanced Lap Times & Performance Analysis
Display instant speed, timing splits, live data and delta lap times on a high-contrast display with an accuracy of up to two-hundredths of a second. See your exact racing line, compare it to optimal lines for faster lap times, track the vehicle's movements and provide detailed data on acceleration, braking, and cornering forces. Do all of this and more with direct ECU data logging for instant, trackside, or post-race analysis with all your logged performance data.
Why Choose the Track Day Solo 2 DL 
Building on the features of the Aim Solo 2 model, the Solo 2 DL motorsport lap timer connects directly to the vehicle's ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and vehicle ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
AiM Car Aim Solo 2 DL GPS and ECU track day lap timer with compact display and mounting bracket
On-Screen Delta Feedback
The Solo 2 DL has a sharp, high-contrast display which helps drivers easily identify the data displayed on screen, as well as 8 different backlight colours.
Whether it's used for point-to-point runs for rallying or a closed-loop track, the Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Inertial Platform
Mounting Options
To take your data one step further, the Aim Solo 2 DL seamlessly connects to Aim SmartyCams and a variety of vehicle sensors to increase your data performance and enhance your analysis with the added visuals and overlays, as well as additional sensor information.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SKU: SOLO2-K2
Solo 2 DL pinout
  • Solo 2 DL front view
    Solo 2 DL
  • Cable icon
    Power Cable with AC Adapter
  • Cable icon
    Your Chosen Connection Cable
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
Videos
Overview
Ladda video: An in-depth review of the main features and functions of the Aim Solo 2 DL track day lap timer.
What is the best track day lap timer?
The Aim Solo 2 DL is a high-precision, 25Hz GPS lap timer. It connects directly to your vehicle’s ECU to provide detailed performance data such as speed, RPM, throttle position and more. It provides accurate lap times, split times and predictive timing, with advanced data logging capabilities, making it one of the best compact data logging lap timers with an integrated display for track days.
How does the Aim Solo 2 DL motorsport lap timer work?
The Aim Solo 2 DL is a GPS lap timer that allows you to analyse instant speed, timing splits, live data and predictive, theoretical and delta times. It connects directly to the car's ECU and multiple satellite constellations (GPS and GLONASS), providing performance data in real time.
The Aim Solo 2 DL uses a range of different technologies to enhance user experience. It has a 25Hz GPS receiver for precise lap timings and position markers, a 100Hz 6-axis inertial platform that provides data on roll, pitch and yaw. It also has integrated data logging capabilities via CAN bus, for advanced and comprehensive data collection.
How do you connect the Aim Solo 2 DL to the car’s system?
The Aim Solo 2 DL manages all the hardware ECU connections as well as all the communication lines: CAN, RS232 or K-Line. Choose between the CAN/RS232 external power cable, CAN/K-Line/external power cable with the OBDII connector or RPM/external power cable. If your car doesn't have an ECU, you can connect the Solo 2 DL to an RPM wave to synchronise RPM to the position on the track thanks to the RPM power cable.
The Solo 2 DL can work seamlessly with our SmartyCam 3 series for data overlay and high-quality recordings. It can also be paired with an Aim ACC3 to add 4 additional analogue channels for external sensors. Data Hubs can also be added to the system to provide additional CAN channels, which is ideal if you're already using the CAN expansion port. Please see the "Connections" tab for more examples.
How do you add a new track to the Race Studio 3 database?
There are more than 4,000 pre-loaded track maps in the Race Studio 3 database. However, you can add an open or closed circuit in Menu > Type of Racing > Circuit Type, then select the "TRACK" and "CREATE" buttons. Follow the prompts onscreen or take a look at our track creation guide for more information on how to set up open or closed circuits.
Aim Solo 2
  • 4GB internal memory
  • Database with over 4,000 tracks worldwide
  • Automatic track recognition
  • Integrated GPS
  • Multiple race modes: Speed, times & performance
  • 10 configurable RGB LEDs
  • Wi-Fi connectability
  • Suitable for any motorsport vehicle
  • GLONASS receiver
  • Direct ECU data logging
  • Predictive lap timing
  • Choice of connection
  • 4GB Internal Memory
  • Automatic Track Recognition
  • Integrated GPS
  • Ten Configurable RGB LEDs
  • Wi-fi Connectability
  • Graphical Display
  • Solo 2 DL
  • Wall charger with AC adaptor
  • Choice of connection cable
  • Solo 2
  • GPS: 25Hz
  • Memory: 4GB
  • GPS: 25Hz
  • Memory: 4GB
