Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Super B Be In Charge Monitoring Kit - AimShop.com
    BICMK
    £400.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £400.00
    Super B Be In Charge Monitoring Kit provides important information about the condition and usage of the battery to detect possible issues. It's compatible with Nomia, Nomada & Epsilon batteries
    Super B Lithium Battery Accessories
    What Is The Be In Charge Monitoring Kit
    The Super B Be In Charge Monitoring Kit provides important information about the condition and usage of the battery, so you can easily detect possible issues.
    Compatible Batteries
    The standard battery monitoring kit is compatible with Nomia 12V210Ah / 12V340Ah, Nomada, Battery Interface Box and Battery Communication Interface. The Be In Charge Monitoring Kit Light is only compatible with Epsilon 12V100Ah / 12V150Ah batteries.
    Mobile App
    Super B provides a Be In Charge Software, which can be used to read out the internal BMS system. The software uses a CAN to USB converter to connect to the communication interface. The software is capable of reading out the actual status, like battery / cell voltages and temperature, but also statistical information. The Be In Charge software can also be used to update the installed firmware of the Li-ion battery. The Be In Charge software and hardware are not part of the Li-ion battery scope of delivery. Super B also provides a Be In Charge App for mobile devices such as Android and IOS. The app can be found in the Google Play Store or Apple App Store.
    Super B App Software
    • Vanliga frågor
    • Programvara
    • Supportvideor
    • Produktguide PDF
    • Kontakta oss
    • Bli ambassadör
    • Reparationer
    • Livechatt & Support
    • Öppnas i ett nytt fönster.
