This MXsl is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
Compact Racing Display
The Aim MXsl dash display is an evolution of the hugely successful MXS Strada dash display, which is one of the most widely used racing dash displays on tracks and streets all over the world.
The MXSL 5" Display integrated into a car dashboard on a racetrack
Why Choose the MXsl Dash Display
The MXsl has a 5″ compact colour display, configurable to show all the information coming from your ECU. It also has analogue/digital inputs, pre-defined math channels, and an optional GPS Module.
The main addition to the Aim MXsl dash display is the inbuilt power module; offering 10 high-power outputs that can be used to directly power components such as motors, lights, fans, pumps and other electrical devices without the need to use conventional relays and fuses.
MXsl Capabilities
The MXsl can detect short circuits, over-currents and open circuits while recording them for later diagnosis. The error information can also be displayed on the dash if required. Each power output can also be configured to be activated by a combination of math channels, analogue/digital inputs, push buttons or ECU fields.
You can automatically run external systems such as to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps etcetera, when a certain event happens.
High Contrast TFT Display
The Aim MXsl has a high contrast TFT display which features an optimised backlighting system by using an ambient light sensor. This helps to maintain the optimum brightness for reading the display in all light levels.
As with other Aim dash displays, the data shown on the screen can be configured to show the precise information that the driver needs the most.
Multiple pages are also available to display further data and can be switched using the buttons on the dash or by wiring to a standalone button. Data which can be displayed include graphical dials for speed and RPM as well as vital engine parameters such as oil pressure/temperature, water temperature, battery voltage and more.
At the top of the unit, there is a row of fully configurable shift lights which can be set according to the user's specific requirements including individual RPM thresholds for each gear and the colour of the LEDs.
Indlæs video: Delta times LED display feedback on the MXSl 5 inch Display
Indlæs video: Integrated shift light array interface and customisable alarms for the MXSL
10 multi-coloured RGB shift lights can be customised, defining the RPM threshold for every gear.
The same flexibility applies to the configurable RGB alarm LEDs: you can configure them to turn on/off depending on analogue or digital inputs, ECU values, expansion values, math channels or GPS information.
Monitoring Your Data
The Aim MXsl shows, together with the RPM scale, all the data you need: speed, water temperature, oil pressure, lap times, and more.
Choose from custom pages among a wide library of page styles, defining which data is shown, and swapping between the pages is easy using the push buttons.
Indlæs video: Pre-configured dash display screens for the MX Strada Series.
Pre-Configured Pages
The MXsl shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
MXsl Expansions list; SmartyCam 3 Sport, ACC3, Data Hub, GPS and more.
Turn your MXsl Dash into a complete data logging system with the MX Strada Logger, Data Hub & GPS09 Module. You can also integrate an ACC3 and convert your analogue to CAN, integrating a camera and various sensors into your setup.
  • Ambient Light Sensor: Yes
  • Alarm LEDs: 6 RGB freely configurable
  • CAN Connections: 3
  • Expansion CAN Connection: GPS, Channel Expansions, Thermocouple Expansions, Lambda Controllers, SmartyCam
  • 8 Fully Configurable Inputs: Analogue, digital, pull up/down, on/off – max 1,000Hz each
  • Speed Input: 1
  • RPM Input: 1
  • Digital Outputs Low Side: 2 (1 Amp max)
  • Digital Outputs High Side:
  • - 10 protected (overcurrent, short circuit to ground and battery, overtemperature, open load detection, current fuse programmable)
  • - 8 5A outputs, 2 10A outputs
  • - Current sense
  • - Output PWM capable (100Hz to 400Hz)
  • Body: Anodised aluminium
  • Connectors: 2 AMP connectors
  • Power Consumption: 400mA without power output lines active
  • Display: 5" TFT
  • Contrast: 600:1
  • Weight: 480g
SKU: MXSL
MXsl Tech Sheet
MXsl Dash Display
MXS Strada
  • 5" TFT display
  • 3 CAN connections
  • 10 shift light RGB LEDs
  • 6 alarm RGB LEDs
  • 10 High-power outputs
  • Data logging
  • ECU connection
  • Digital output
  • 5" TFT display
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • Weight: 480g
  • Weight: 480g
  • MXsl
  • MXS Strada Dash
  • 14-Pin Standard Wiring
  • Speed Input: 1
  • RPM Input: 1
    - Current sense
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Display: 5" TFT
  • Contrast: 600:1
  • Display: 5" TFT
