Advanced PDM Display
The 6" PDM display with road icons is one of the most widely used PDM displays on roads around the world. Its compact size makes it suitable for use as a replacement unit for those supplied with the Aim PDM kits or an upgrade for PDM kits that do not include a dash display.
The PDM08 and PDM32 6" Display integrated into a car dashboard
Why Choose the 6” PDM Display
The 6" PDM display is a TFT dash display suitable for replacing all of the dashboard gauges and warning lamps. The displays are available in 5”, 6" or 10" versions and with both "Road" or "Race" icon options. All versions have fully user-configurable displays and offer a range of layouts.
Please Note: The 6" dash display is ONLY for use with Aim PDM kits and can not be used as a stand-alone dash display.
The PDM08 and PDM32 Modules
Power Distribution Modules
Display with Road Icons
The dash has a 6" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.
Video laden: Delta times LED display feedback on the PDM Display
Video laden: Integrated shift light array interface and customisable alarms for the PDM Dash Displays
Video laden: Pre-configured dash display screens for the PDM Dash Displays
Pre-Configured Pages
The Aim PDM 6" Display can show the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
Reversing camera with PDM dash
Integrate a Reverse Camera
Data from Race Studio 3 showing the configurable dash displays
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
PDM Dash Displays Expansions list; SmartyCam, ACC3, Data Hub, GPS and more.
Add extra devices to your system to give additional data to improve your driving performance, such as a GPS Module, SmartyCams, Lambda Controller, Formula Steering Wheel, TPMS System and Keypads.
The 6" road display also doubles up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. The camera is sold separately.
  • Ambient Light Sensor: Yes
  • Status Information LEDs: 5 LEDs
  • Body: Anodised aluminium
  • Power Consumption: 150mA
  • Display: 6" TFT
  • Contrast: 600:1
  • Weight: 640g
SKU: DISPLAY-6-I-XC1D06000
6" PDM Display Pinout
6" Technisches Datenblatt für PDM-Displays
PDM08 User Guide
PDM08 Tech Sheet
PDM32 User Guide
PDM32 Tech Sheet
  • 5" TFT display
  • 10 shift light RGB LEDs
  • Road icons
  • 6 status information LEDs
  • Fully configurable display
  • Range of layouts
  • 6" TFT display
  • Road icons
  • 5 status information LEDs
  • Range of layouts
  • 10" TFT display
  • Road icons
  • Range of layouts
  • Weight: 530g
  • Weight: 640g
  • Weight: 1,000g
  • 5" TFT Dash Display
  • 6" TFT Dash Display
  • 10" TFT Dash Display
  • Status Information LEDs: 6
  • Body: Anodised Aluminium
  • Power Consumption: 400mA
  • Power Consumption: 250mA
  • Display: 5" TFT
  • Display: 6" TFT
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Brightness: 800cd/m²
What are the best applications for the 6" PDM display with road icons?
The 6" PDM display with road icons is best suited to road-registered performance cars, kit cars and track-day vehicles that require street-legal functionality in compact cockpits.
Which alarms can be set on the 6" PDM display?
The Aim 6" PDM display features fully customisable alarms that are configurable to trigger by almost any sensor, ECU value or system status via Race Studio 3. Alarms can be displayed as on-screen text, pop-up messages and visual alerts using the 10 RGB LEDs and configurable road icons.
Although the shift lights are designed for optimum gear shifting, you can use a math channel to customise them to what you want them to be. For example, a math channel can be used to multiply GPS speed by 1 and have the output as an engine RPM. Using that math channel as the shift light RPM, you have now got speed on the shift lights.
