Advanced Power Distribution Module
The Aim PDM32 is a 32-channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions.
Why Choose the PDM32
The PDM32 is available on its own or with a choice of 5", 6" or 10" dash displays. It also capable of receiving data from the vehicles ECU and even includes a data logger and GPS module for lap timing and track mapping.
With a total continuous max current of 120A, each of the outputs provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, the number of fault reties and the time between the reties is user definable. All outputs can be configured as PWM's for a soft start/stop. All of the PDM circuits can be set up and monitored via the Race Studio 3 software.
PDM32 Data Management
The PDM32 can receive and record data from the following sources:
  • Digital/analogue inputs
  • Internal 9-axis EMU
  • GPS: Lap time and position
  • Expansion Modules
  • Push buttons from RIO02 (Remote Input Output module) or any commercial CAN keypad
  • PDM Outputs: Currents and status of each channel individually
  • Other user-defined math channels
Optional Wiring Solutions
GPS Options
The GPS09 module option provides easy lap timing and lap position for track mapping. The PDM has over 4,000 racetracks in the database, so once you arrive at the track, the system already knows the timing points so that you can get on with the driving.
The GPS09 module is available with various lead lengths to suit different applications and with cable entry from underneath (roof version) or the side.
CAN Keypads
  • LEDs: 32 RGB LEDs, 1 PDM ON & 1 PDM STS (status)
  • Inputs: 14 fully configurable (max 500Hz each) - 8 analogue/digital, 4 digital inputs & 2 speed inputs
  • Lin Bus: 1
  • CAN Connections: 3
  • Internal Platform: 3-axis ±5G accelerometer, 3-axis gyro & 3-axis magnetometer
  • Internal Memory: 4GB
  • External Modules: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Memory Module, Remote I/O Push-Button Module.
  • External Analogue Camera Input: 2
  • Connectors: 2 AMP connector, 2 binder connectors, 1 Amphenol SurLok connector & 1 Rosenberger connector
  • Remote Display Connection: 1 Aim stream output
  • Body: Anodised aluminium
Power Outputs
  • 4 rated up to 20A (high power)
  • 12 rated up to 15A (mild power)
  • 12 rated up to 10A (low bridge)
  • 4 rated up to 35A (high side/half bridge/low side/configurable PWM at max 10KHz)
  • Protected For: Over-voltage, under-voltage, over-current, over-temperature
  • Total Max Current: 120A
  • Dimensions: 234.5 x 94.6 x 49.5mm
  • Weight: 761g
  • AiM Power Distribution Module PDM32 - Module Only - AimShop.com
    PDM32
  • Grey & Black 35-Pin Plug & 70 Gold Pins
  • CAN Expansion Cable
  • SurLok Power Connector
  • Download Cable
PDM32 User Guide
PDM32 Tech Sheet
